Vyos firewall rules ansible issue
Can’t seem to get firewall rules made using this module on vyos version 1.4.1 or 1.5-rolling
Ansible Version
➜ ansible --version
ansible [core 2.17.6]
  config file = /home/oli/git-personal/vyos/home-lab/ansible.cfg
  configured module search path = ['/home/oli/.ansible/plugins/modules', '/usr/share/ansible/plugins/modules']
  ansible python module location = /nix/store/68q8gz6ayd8z9ywi4109w02dd35smwc0-python3.12-ansible-core-2.17.6/lib/python3.12/site-packages/ansible
  ansible collection location = /home/oli/.ansible/collections:/usr/share/ansible/collections
  executable location = /nix/store/68q8gz6ayd8z9ywi4109w02dd35smwc0-python3.12-ansible-core-2.17.6/bin/ansible
  python version = 3.12.8 (main, Dec  3 2024, 18:42:41) [GCC 13.3.0] (/nix/store/kjgslpdqchx1sm7a5h9xibi5rrqcqfnl-python3-3.12.8/bin/python3.12)
  jinja version = 3.1.5
  libyaml = True
➜ ansible-galaxy collection list
# /home/oli/.ansible/collections/ansible_collections
Collection                               Version
ansible.netcommon                        7.1.0
ansible.posix                            2.0.0
ansible.utils                            4.1.0
community.crypto                         2.22.3
community.docker                         4.1.0
community.general                        10.1.0
community.library_inventory_filtering_v1 1.0.0
community.libvirt                        1.3.0
community.mysql                          1.5.1
containers.podman                        1.16.2
freeipa.ansible_freeipa                  1.13.1
gluster.gluster                          1.0.2
kubernetes.core                          4.0.0
openstack.cloud                          2.2.0
openstack.kolla                          1.0.0
vyos.vyos                                5.0.0
vars.yml
inbound_firewall:
  - name: VM-ACCESS
    ip-version: 4
    default_action: drop
    description: Allow access Network
    log: true
    rules:
      - number: 13370
        description: allow in to ip
        protocol: udp
        destination:
          address: 192.168.1.1
          group:
            port_group: WEBSERVER
        action: accept
        disable: true
        log: enable
playbook.yml
- name: Merge the provided configuration with the existing running configuration
  vyos.vyos.vyos_firewall_rules:
    config:
      - afi: ipv4
        rule_sets:
          - name: "{{ item.name }}"
            description: "{{ item.description }}"
            default_action: "{{ item.default_action }}"
            rules: "{{ item.rules }}"
    state: merged
  loop: "{{ inbound_firewall }}"
Error:
 "module_stderr": "set firewall name VM-ACCESS description 'Allow access Network\r\n\r\n  Configuration path: firewall [name] is not valid\r\n  Set failed\r\n\r\n[edit]\r\r\noli@firewall# ",
Its like its not finding its version 1.4+ and adding in the set firewall ipv4 syntax from the module
https://docs.ansible.com/ansible/latest/collections/vyos/vyos/vyos_firewall_rules_module.html
