I am building a VyOs system and going with
- quad core Intel i5-7500 (4 x 3.4GHz)
- Gigabyte GA-H270N-WIFI
- 8GB Ram
- 120GB SSD (overkill, but had lying around)
- Intel 350T4 quad port PCIe card.
I know the CPU is likely very much overkill, but I am coming from an Edge Router that was CPU constrained when I tried to add firewall rules to apply DSCP tags and then traffic shape based on those tags. I prefer to have more CPU than needed, than not enough. If I let the CPU go to lower power modes I hope to just have the headroom for when needed.
Where can I find a list of what drivers are in VyOS to know if the Nic will work? IS there a preferred multi-port NIC that the drivers are built in?
Thanks!
