Hi Guys,
We a Dell Power Edge 1950 running VyOS 1.1.7, 16Gbps of RAM and Processor Intel Xeon E5450:
amascarenhas@goc-spo1-rtr-01:~$ sh version
Version: VyOS 1.1.7
Description: VyOS 1.1.7 (helium)
Copyright: 2016 VyOS maintainers and contributors
Built by: maintainers@vyos.net
Built on: Wed Feb 17 09:57:31 UTC 2016
Build ID: 1602170957-4459750
System type: x86 64-bit
Boot via: image
HW model: PowerEdge 1950
HW S/N: 3MZHLH1
HW UUID: 44454C4C-4D00-105A-8048-B3C04F4C4831
amascarenhas@goc-spo1-rtr-01:~$ show system memory
Total: 16050
Free: 14714
Used: 1336
We note that the router is rebooted always in the same hour (1:58 am) in sporadic days.
We’d like a help to understand why this occurs. We deactivate the flow exporting to mitigate the issue, but We’d like to track it.
We check schedulers, crons and etc… but We didn’t find anything.
Could you help us?
Regards,
André Mascarenhas
did you check system log around 1:58am, and space’s hard disk ?
Hi Guys,
It’s look fine:
root@goc-spo1-rtr-01:/home/amascarenhas# df -kh
Filesystem Size Used Avail Use% Mounted on
overlayfs 134G 331M 127G 1% /
tmpfs 7.9G 0 7.9G 0% /lib/init/rw
udev 7.9G 236K 7.9G 1% /dev
tmpfs 7.9G 4.0K 7.9G 1% /dev/shm
/dev/sda1 134G 331M 127G 1% /live/image
/dev/sda1 134G 331M 127G 1% /live/cow
tmpfs 7.9G 0 7.9G 0% /live
tmpfs 7.9G 36K 7.9G 1% /tmp
/dev/sda1 134G 331M 127G 1% /opt/vyatta/etc/config
tmpfs 7.9G 84K 7.9G 1% /var/run
none 7.9G 1.8M 7.9G 1% /opt/vyatta/config
Regards,
And your system log when your VM reboot,…
Do you think it’s about a snapshot during a backup for example ?
Hi Friend, It seems not.
I’ve searched in many directories for the correspondent logs but didn’t find anything.
We note that after shutdown the Netflow process the We didn’t have any issue.
About the snapshot, I’m asking to the Xen Server manager ok.
Regards,
André Mascarenhas
Sorry, about the snapshot, the Server is physical! So We don’t have any policy about.
Regards
