Vyos high cpu usage
Vyos high cpu usage out of 4 core 1 core is used 100%. Using top I realized ksoftirqd/0 is using cpu. Vyos is running running as proxmox vm.
Without any info it is very hard to extract a problem or provide a solution for what you observe. For what it’s worth you could be pushing 10gbit through the router and be amazed a core maxes out.
Please provide info with your help questions or big report.
traffic passimg through is 400mbps upload and download. Basically running pppoe server. almost 450 subscriber were connected and also running cgnat
Please add the output of “show config commands | strip-private” to your forumthread.
irewall global-options
set firewall ipv4 forward filter rule 50 action ‘drop’
set firewall ipv4 forward filter rule 50 description ‘Drop QUIC’
set firewall ipv4 forward filter rule 50 destination port ‘80,443’
set firewall ipv4 forward filter rule 50 protocol ‘udp’
set firewall ipv4 forward filter rule 100 action ‘accept’
set firewall ipv4 forward filter rule 100 destination port ‘80,443’
set firewall ipv4 forward filter rule 100 log
set firewall ipv4 forward filter rule 100 log-options level ‘debug’
set firewall ipv4 forward filter rule 100 protocol ‘tcp’
set firewall ipv4 forward filter rule 100 state ‘new’
set firewall ipv6 forward filter rule 50 action ‘drop’
set firewall ipv6 forward filter rule 50 description ‘Drop QUIC’
set firewall ipv6 forward filter rule 50 destination port ‘80,443’
set firewall ipv6 forward filter rule 50 protocol ‘udp’
set firewall ipv6 forward filter rule 100 action ‘accept’
set firewall ipv6 forward filter rule 100 destination port ‘80,443’
set firewall ipv6 forward filter rule 100 log
set firewall ipv6 forward filter rule 100 log-options level ‘debug’
set firewall ipv6 forward filter rule 100 protocol ‘tcp’
set firewall ipv6 forward filter rule 100 state ‘new’
set interfaces ethernet eth0 hw-id ‘xx:xx:xx:xx:xx:fd’
set interfaces ethernet eth0 vif 321 description ‘Kamran-Distri’
set interfaces ethernet eth0 vif 321 disable
set interfaces ethernet eth0 vif 362 description ‘Ijaz-Distri’
set interfaces ethernet eth0 vif 362 disable
set interfaces ethernet eth0 vif 401 address ‘xxx.xxx.135.172/26’
set interfaces ethernet eth0 vif 401 address ‘xxxx:xxxx:0:1::2/64’
set interfaces ethernet eth0 vif 3901 description ‘DC-IPv6-1’
set interfaces loopback lo
set nat cgnat pool external ext1 external-port-range ‘1001-65535’
set nat cgnat pool external ext1 per-user-limit port ‘1000’
set nat cgnat pool external ext1 range xxx.xxx.209.48/29
set nat cgnat pool external ext1 range xxx.xxx.209.56/29
set nat cgnat pool internal ConPool range ‘xxx.xxx.0.0/22’
set nat cgnat rule 10 source pool ‘ConPool’
set nat cgnat rule 10 translation pool ‘ext1’
set nat64 source rule 100 source prefix ‘xxxx:xxxx::/96’
set nat64 source rule 100 translation pool 10 address ‘xxx.xxx.209.2’
set nat64 source rule 100 translation pool 10 port ‘1025-65535’
set protocols static route xxx.xxx.0.0/0 next-hop xxx.xxx.135.177
set protocols static route6 ::/0 next-hop xxxx:xxxx:0:1::1
set service dns
set service ntp allow-client xxxxxx ‘xxx.xxx.0.0/8’
set service ntp allow-client xxxxxx ‘xxx.xxx.0.0/16’
set service ntp allow-client xxxxxx ‘xxx.xxx.0.0/12’
set service ntp allow-client xxxxxx ‘::1/128’
set service ntp allow-client xxxxxx ‘fe80::/10’
set service ntp allow-client xxxxxx ‘fc00::/7’
set service ntp allow-client xxxxxx ‘xxx.xxx.0.0/0’
set service ntp allow-client xxxxxx ‘::/0’
set service pppoe-server authentication mode ‘radius’
set service pppoe-server authentication protocols ‘pap’
set service pppoe-server authentication protocols ‘chap’
set service pppoe-server authentication protocols ‘mschap’
set service pppoe-server authentication protocols ‘mschap-v2’
set service pppoe-server authentication radius accounting-interim-interval ‘180’
set service pppoe-server authentication radius dynamic-author key xxxxxx
set service pppoe-server authentication radius dynamic-author port ‘3799’
set service pppoe-server authentication radius dynamic-author server ‘xxx.xxx.135.172’
set service pppoe-server authentication radius nas-identifier ‘VyOS’
set service pppoe-server authentication radius nas-ip-address ‘xxx.xxx.135.172’
set service pppoe-server authentication radius rate-limit attribute ‘Mikrotik-Rate-Limit’
set service pppoe-server authentication radius rate-limit enable
set service pppoe-server authentication radius rate-limit vendor ‘Mikrotik’
set service pppoe-server authentication radius server xxxxx.tld disable
set service pppoe-server authentication radius server xxxxx.tld key xxxxxx
set service pppoe-server authentication radius source-address ‘xxx.xxx.135.172’
set service pppoe-server client-ip-pool Con-Pool range ‘xxx.xxx.0.0/22’
set service pppoe-server client-ip-pool expired-pool range ‘xxx.xxx.0.0/22’
set service pppoe-server client-ipv6-pool delegate-prefix delegate xxxx:xxxx:3::/56 delegation-prefix ‘64’
set service pppoe-server client-ipv6-pool delegate-prefix prefix xxxx:xxxx:2::/56 mask ‘64’
set service pppoe-server default-pool ‘Con-Pool’
set service pppoe-server gateway-address ‘xxx.xxx.1.1’
set service pppoe-server interface eth0.3901
set service pppoe-server name-server ‘xxx.xxx.135.166’
set service pppoe-server name-server ‘xxxx:xxxx:4860::6464’
set service pppoe-server pado-delay 50 sessions ‘500’
set service pppoe-server pado-delay 100 sessions ‘1000’
set service pppoe-server ppp-options disable-ccp
set service pppoe-server ppp-options ipv4 ‘allow’
set service pppoe-server ppp-options ipv6 ‘allow’
set service router-advert interface eth0 default-lifetime ‘3600’
set service router-advert interface eth0 default-preference ‘high’
set service router-advert interface eth0 hop-limit ‘64’
set service router-advert interface eth0 interval max ‘30’
set service router-advert interface eth0 link-mtu ‘1450’
set service router-advert interface eth0 name-server ‘xxxx:xxxx:4860::6464’
set service router-advert interface eth0 prefix ::/64 preferred-lifetime ‘3600’
set service router-advert interface eth0 prefix ::/64 valid-lifetime ‘7200’
set service router-advert interface eth0 reachable-time ‘300’
set service router-advert interface eth0 retrans-timer ‘100’
set service snmp community corbis
set service ssh
set system host-name xxxxxx
set system logs logrotate messages max-size ‘1024’
set system logs logrotate messages rotate ‘5’
set system name-server ‘xxx.xxx.135.166’
set system option performance ‘throughput’
set system syslog global facility local7 level ‘debug’
set system syslog host xxx.xxx.135.171 facility kern level ‘all’
set system syslog host xxx.xxx.135.171 port ‘514’
set system update-check url xxxxxx
I’ve never used accel-ppp I wonder does Vyos set thread-count= option?
Anyway to get a copy of the config file Vyos generates for accel-ppp and see if that option is set?
edit: This thread says it’s supported. How many CPUs does your system have?
4 cpu core are present in my setup
thread count is set properly set to 4 equals to core count. I don’t thinks the issue is related to accel-ppp. Issue is something else. Previously I tested on physical machine there was no issue. Now, vyos is running on Proxmox. I think its kvm related issue
Could it be there’s something wrong in your network and the vyos vm is seeing a lot of traffic for which is not the destination? Ie, your virtual network flooding all traffic towards vyos?
nope there is no problem in network. I have checked
What CPU type are you using under Proxmox?
I am using host cpu type
well , there are many points where you can improve , enable multiquee on KVM/promox to the virtual NIC , also if you are using intel, it’s recomended disabled the HT to high trought VMs , check max ring buffer enable and try to play with the offload.
Also since CGNAT is used dont forget to tweak the conntrack tables size preferly 1:1 hash/bucket ratio (for performance).
Edit: Also consider/test these optimizations and see which one will improve your situation:
