Vyos in containerlab switch issue
Note that you can use another VyOS node as a bridge device as well, instead of using additional docker bridges.
but when i test this feature, it seems not work fine.
root@hive:~/kind/clab/bridge-mode# cat vyos.yaml
topology:
  nodes:
    # vRouter1
    vyos1:
      kind: linux
      image: vyos/vyos:1.2.8
      cmd: /sbin/init
      binds:
        - /lib/modules:/lib/modules
    # vRouter2
    vyos2:
      kind: linux
      cmd: /sbin/init
      binds:
    # vSwitch
    vyos3:
      kind: linux
      cmd: /sbin/init
      binds:
  links:
    - endpoints: ["vyos1:eth1", "vyos3:eth1"]
    - endpoints: ["vyos2:eth1", "vyos3:eth2"]
hi @eBPFCilium , could you please tell what exactly doesn’t work as expected and what is the configuration you’re running on that nodes?
with vyos 1.4, all the node work fine
