It works
Things like setting the duplex and link speed of ethernet interfaces fail, and there seems to be no way to remove these from the config (I tried both manually removing from config.boot / delete int eth eth0 duplex auto but they just keep re-appearing)
If you can ignore those errors when committing ethernet interface configuration the basic functionality seems ok. I haven’t tried any exotic configurations so YMMV.
Great! Would you mind sharing how you did it? Did you somehow unpack the ISO inside an lxd container, or build VyOS from source inside a container, or …?
Is anyone else following this? Now there is good news, I have implemented a preliminary implementation of Vyos on lXD, if you are interested, you are welcome to contribute or improve
