Basically I need to setup ipsec vpn on two vti interface and my bgp works on two vti interface but I need to do primary and secondary. Right now my both vti bgp work but when my primary interface goes down its move to secondary but when my primary goes up its not move to primary again can u please help for this.
Play around with commands like below, to make one path preferred over the other
set protocols bgp 65505 neighbor 10.0.0.26 weight 10
set protocols bgp 65505 neighbor 10.0.0.22 weight 20
On opposing router, you need similar commands
These aren’t your full configs, but if you’re only using BGP between these 2 routers…I’d be using OSPF
basically i configure vyos router on two aws account and my vpn tunnel show up and i am able to ping my internal ip that i am using in vyos router both side but when i try to ping internal machine that already running in same network i unable to do this can please guide me about this as well
