Firstly: Hello to everyone as this is my first post.
Secondly: I’ve got VyOS running on mini-ITX board with Intel Cel. J1900. I will be installing Sierra Wireless MC7304 LTE modem on the board to work as my failover. Has anyone attempted to marry LTE modem with VyOS? I would prefer to use it in qmi_wwan mode (rather than ppp). I die for some information in this matter as I have been unsuccessful so far.
VyOS has limited to no support for wi-fi and 3g/LTE
Maybe a good reason to submit a feature request(please spend some time to describe it well. About qmi_wwan and in general)
Thanks!
Thank you for the answer. From what you say I understand that the modem should work in standard PPP mode, right? Is there any how-to guide on that (I didn’t find any on forum or website).
you almost for sure will get issues with drivers, 1.1.x is pretty old
1.2 betas is more freshier, but it still far away from stable
I’m not sure if ppp will work, will check with devs
Thanks for the above. I’m running the latest beta anyway since stable 1.1.7 does not want to install. Just two questions now:
When will devs answer?
Where can I get any changelogs for betas?
Thanks!
EDIT:
I installed modem today and it’s showing up in the system:
Also, I’ve got two new devices. That means qmi_wwan driver is loaded correctly:
Just to confirm I run dmesg:
Now, how to use the damn thing now?
EDIT2:
From linux commands I can get to the following:
Unfortunately WWAN0 and WWAN1 do not show as interfaces in VyOS config cli anywhere. I guess they should be appearing in interfaces->wirelessmodem or elsewhere… Any good idea?
3G modem is quite a neglected feature. It needs someone who loves them enough to go through the trouble of re-designing and re-writing it from scratch.
Right now it only has hardcoded initialization strings for american AT&T, T-mobile, and Verizon. Modems that look like ethernet interfaces definitely have never been supported.
If you want to take up this task, you are welcome.
We have been working on this exact same thing since last November without much success so far. We are working with a Nimblelink modem. This would be an extremely useful feature.
For now I’m forced to stick with RouterOS which I hate, but it works fine. When I have time I’ll give Endian a go. Quick look tells me it’s worth a shot.
Sorry for the delay. Here is what ended up working for us.
Edit /opt/vyatta/etc/config/scripts/vyatta-postconfig-bootup.script and add the following lines. You can also do this from the CLI first to see if the modem will enumerate.
modprobe option
echo 1bc7 1201 > /sys/bus/usb-serial/drivers/option1/new_id
(this should make the modem enumerate under /dev if it hasn’t already.)
you can identify the hex needed in the previous command by issuing lsusb
Then create interface wlm101
set interfaces wirelessmodem wlm101 device ttyUSB3
set interfaces wirelessmodem wlm101 network att
commit
edit the chat scripts in /etc/ppp/peers to inculde ONLY the following text:
att-TNAG-chat
TIMEOUT 35
ECHO ON
‘’ \rATZ
OK ‘ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0’
OK AT+CGDCONT=1,“IP”,“broadband”,“0.0.0.0”,0,0
OK ATD99**1#
CONNECT ‘’
Additional notes:
Signal strength
sudo screen /dev/ttyUSB4
AT+CSQ
DIAGNOSTICS
lsusb Shows modem identifier (1bc7 …)
sudo screen /dev/ttyUSB3 115200
AT OK response
AT+CSQ check signal strength
to quit (ctrl+a ctrl+d)
I apologize for the delay. This forum has helped me out a great deal. And I hope to contribute something useful.
No doubts - interest is still her
Share you solution and i can transfer it to wiki for you(or you can do it directly there and post link here)
Thanks for willing to share!
Thanks for this. You mentioned “edit the chat scripts”. Can you explain what this means.
Also, do you what lines would need to change for T-Mobile and where to find those changes?
