I find that after reboot the Vyos router does not load the full config. It misses to load the vxlan and bridge config.
bridge br241 {
address 172.0.0.1/24
member {
interface eth0.241 {
interface vxlan241 {
hw-id 08:00:27:b7:79:e6
vif 241 {
address 10.1.2.2/24
hw-id 08:00:27:d8:22:d4
mtu 1700
ethernet eth2 {
address dhcp
hw-id 08:00:27:5e:2f:57
loopback lo {
vti vti10 {
address 10.0.0.2/31
mtu 9000
vxlan vxlan241 {
link vti10
mtu 1500
remote 10.0.0.3
vni 241
thanks for checking it and helping.
tjh
April 6, 2020, 7:59pm
2
You don’t mention what version of Vyos you’re using?
I am testing with 1.3-rolling-202004051749 .
c-po
April 7, 2020, 6:10am
4
Can you please share your config before you upgraded? Which version did you upgrade from?
The work around solution that I found works is …
vyos@leaf2# cat /config/scripts/vyos-postconfig-bootup.script
#!/bin/vbash
configure
load
commit
ip link set vti10 up
c-po
April 8, 2020, 3:41pm
8
This is indeed a very interesting configuration. There is a race condition on system startup with the VTI interfaces.
Further handling of this bug is done via ⚓ T2243 Bridge interface fails if member is VXLAN interface with VTI underlay . Thanks for reporting.
