I make changes to the ntp config in vyos and it does not appear to show up in the /etc/ntp.conf , I noticed this after I went into the file to tune the ntp settings. I have removed all the ntp.org servers from the config and added our internal servers but the ntp.org servers persist and ours do not show up. I am running VyOS 1.4-rolling-202104051959. Any ideas?
cat /etc/ntp.conf
/etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
Leap seconds definition provided by tzdata
leapfile /usr/share/zoneinfo/leap-seconds.list
Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
You do need to talk to an NTP server or two (or three).
#server ntp.your-provider.example
pool.ntp.org maps to about 1000 low-stratum NTP servers. Your server will
pick a different set every time it starts up. Please consider joining the
pool: http://www.pool.ntp.org/join.html
pool 0.debian.pool.ntp.org iburst
pool 1.debian.pool.ntp.org iburst
pool 2.debian.pool.ntp.org iburst
pool 3.debian.pool.ntp.org iburst
Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
details. The web page http://support.ntp.org/bin/view/Support/AccessRestrictions
might also be helpful.
Note that “restrict” applies to both servers and clients, so a configuration
that might be intended to block requests from certain clients could also end
up blocking replies from your own upstream servers.
By default, exchange time with everybody, but don’t allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery limited
restrict -6 default kod notrap nomodify nopeer noquery limited
Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict ::1
Needed for adding pool entries
restrict source notrap nomodify noquery
Clients from this (example!) subnet have unlimited access, but only if
cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
If you want to provide time to your local subnet, change the next line.
(Again, the address is an example only.)
#broadcast 192.168.123.255
If you want to listen to time broadcasts on your local subnet, de-comment the
next lines. Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient
