VyOS on EVE-NG booting issue
Hi all,
I am new here and have a question regarding VyOS and virtual environment. I downloaded latest VyOS version vyos-1.5-stream-2025-Q1-generic-amd64.iso. I booted up the ISO file in the node in EVE-NG and issued command “install image”. After installation is done, I reboot and VyOS starts booting and stuck in this stage.
Begin: Running /scripts/init-bottom … done.
[ 18.425717] systemd[1]: Inserted module ‘autofs4’
[ 18.527234] systemd[1]: systemd 252.33-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 18.534431] systemd[1]: Detected virtualization kvm.
[ 18.535638] systemd[1]: Detected architecture x86-64.
Welcome to VyOS 1.5-stream-2025-Q1 (circinus)!
[ 18.552249] systemd[1]: Hostname set to .
[ 19.548782] systemd[1]: Queued start job for default target multi-user.target.
[ 19.562723] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ OK ] Created slice system-getty.slice - Slice /system/getty.
[ 19.570383] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ OK ] Created slice system-modpr…lice - Slice /system/modprobe.
[ 19.582046] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ OK ] Created slice system-seria… - Slice /system/serial-getty.
[ 19.593622] systemd[1]: Created slice user.slice - User and Session Slice.
[ OK ] Created slice user.slice - User and Session Slice.
[ 19.600754] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ OK ] Started systemd-ask-passwo…quests to Console Directory Watch.
[ 19.609598] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ OK ] Started systemd-ask-passwo… Requests to Wall Directory Watch.
[ 19.618699] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ OK ] Set up automount proc-sys-…rmats File System Automount Point.
[ 19.627791] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[ OK ] Reached target cryptsetup.…get - Local Encrypted Volumes.
[ 19.633363] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ OK ] Reached target integrityse…Local Integrity Protected Volumes.
[ 19.639043] systemd[1]: Reached target network-online.target - Network is Online.
[ OK ] Reached target network-online.target - Network is Online.
[ 19.645540] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[ OK ] Reached target remote-fs.target - Remote File Systems.
[ 19.651545] systemd[1]: Reached target slices.target - Slice Units.
[ OK ] Reached target slices.target - Slice Units.
[ 19.657099] systemd[1]: Reached target stunnel.target - TLS tunnels for network services - per-config-file target.
[ OK ] Reached target stunnel.tar…services - per-config-file target.
[ 19.665128] systemd[1]: Reached target swap.target - Swaps.
[ OK ] Reached target swap.target - Swaps.
[ 19.670305] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ OK ] Reached target veritysetup… - Local Verity Protected Volumes.
[ 19.678234] systemd[1]: Listening on syslog.socket - Syslog Socket.
[ OK ] Listening on syslog.socket - Syslog Socket.
[ 19.683777] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ OK ] Listening on systemd-initc… initctl Compatibility Named Pipe.
[ 19.693520] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ OK ] Listening on systemd-journ…t - Journal Socket (/dev/log).
[ 19.701023] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ OK ] Listening on systemd-journald.socket - Journal Socket.
[ 19.708330] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ OK ] Listening on systemd-udevd….socket - udev Control Socket.
[ 19.715737] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ OK ] Listening on systemd-udevd…l.socket - udev Kernel Socket.
[ 19.731198] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System…
[ 19.741179] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System…
** Mounting dev-mqueue.mount**
It stays here for long time(really don’t know how long, I guess hours). If I leave it running and then come back next day so I see there is already “vyos login:” login prompt. After that I can login successfully.
I followed steps from even-ng website.
Does anybody have same issues? Why it stuck in this stage? It’s impossible to lab it as I have to wait to have vyos booted properly long time.
Thanks for help.
Best regards,
JR
I use GNS3, but this might be similar to an issue I have at times. It will appear that the boot has stalled, but it’s actually the console session that has locked. Try closing the session, and reopening it.
This helped me. I wait once VyOS boot completely and then just open session. Issue is if oy want to see process of boot process. Is it more emulator bug/issue or VyOS issue? Because I have not experienced this on any Cisco images or other brand images.
Now I have other issue, and it is it shows different ethernet interfaces numbering on other nodes. But I will try to figure this out.
Thanks.
It’s a little bit of both. I don’t have the same issue with any other image I use across multiple vendors, but I also don’t have the issue when using a physical serial port with VyOS. So there’s something with the telnet pipe that is used to access the serial console that seems to cause the issue.
