Do you plan to build a google compute engine iso? (like AWS)
Indeed, I 've tried to import Vyos in Google Compute Engine but it doesn’t work.
(However i rebuild kernel with pre-requisites)
Google told me Debian 6 could be reponsible in this import error.
Regards
kcnz
May 20, 2016, 6:23pm
2
jeffbearer:
I tried to get this imported today using the steps to import a virtualbox disk image . I hit the same error that the OP listed. Even with verbosity turned up it didn’t say exactly why the image was not a valid image but I suspect it is because there is no root filesystem in the root of the partition.
I’d love to be able to get vyos running in GCE but it’s probably going to be a difficult proposition.
I got this working as far as imported and running on GCE, but I can’t get into the box. I could get into it on virtual box before I packaged it up. I assume the networking stuff is not lining up correctly.
My steps…
Create Vitualbox image (Debian 64bit) using vyos-1.1.7-amd64
2048 memory
10 GB drive (QCOW)
disable audio
disable floppy on boot
network/advanced, change to Paravirtualized Network
Setup Vyos
Install to image
Create your password.
setup ssh.
Shutdown Virtualbox Image
Create Raw Image (VboxManage clonehd -format RAW ./Vyos.qcow ~/disk.raw)
tar raw image (gtar -cSzf vyos.tar.gz disk.raw) You must use “Gtar” not just “tar” or you’ll get the bad image error.
gsutil cp vyos.tar.gz gs://some-unique-folder/vyos.tar.gz
gcloud compute images create vyos --source-uri gs://some-unique-folder/vyos.tar.gz
Now create an instance from the image.
My problem is that it starts up but I can’t get into the box. So I need to know how to configure vyos so that it will run on GCE.
Try pre-configuring vyos with proper IP addresses, FW rules, and most important MAC addresses.
Hello guys,
please get your accounts on phabricator.vyos.net
i going to create Project for GCE there
we can continue discussion there.
By the way, we have image on Ravello which uses GCE for their labs, and VyOS boots just fine
kcnz:
jeffbearer:
My steps…
2048 memory
10 GB drive (QCOW)
disable audio
Setup Vyos
Install to image
setup ssh.
hi, i did the same thing and i’m stuck… were you able to make it work?
