I built a vyos openstack iso (based on the current branch as of yesterday of the vyos/vyos-build repo using ‘make openstack’), create the image in openstack, and launched an instance from the image. The vyos/vyos log in does not work (from the console), I cannot ping the instance (after adding a floating IP), and I cannot add a different user via the a #cloud-config. The instance log is below. While it appears that the interface is not coming up, I’m not able to login to verify/debug. Has the ‘openstack’ build been tested and how do I resolve this issue so that I can create an image usable in openstack?
[ 0.000000] Linux version 4.19.84-amd64-vyos (vyos_bld@099fb39c0107) (gcc version 4.9.2 (Debian 4.9.2-10+deb8u2)) #1 SMP Tue Nov 12 21:23:57 UTC 2019
[ 0.000000] Command line: BOOT_IMAGE=/live/vmlinuz boot=live components hostname=vyos username=live nopersistence noautologin nonetworking union=overlay console=ttyS0,115200 console=tty0 initrd=/live/initrd.img
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: ‘MPX bounds registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: ‘MPX CSR’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x020: ‘AVX-512 opmask’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x040: ‘AVX-512 Hi256’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x080: ‘AVX-512 ZMM_Hi256’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: ‘Protection Keys User registers’
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: xstate_offset[5]: 960, xstate_sizes[5]: 64
[ 0.000000] x86/fpu: xstate_offset[6]: 1024, xstate_sizes[6]: 512
[ 0.000000] x86/fpu: xstate_offset[7]: 1536, xstate_sizes[7]: 1024
[ 0.000000] x86/fpu: xstate_offset[9]: 2560, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x2ff, context size is 2568 bytes, using ‘compacted’ format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bffdefff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bffdf000-0x00000000bfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000013fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: OpenStack Foundation OpenStack Nova, BIOS 1.11.0-2.el7 04/01/2014
[ 0.000000] Hypervisor detected: KVM
[ 0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
[ 0.000000] kvm-clock: cpu 0, msr 66053001, primary cpu clock
[ 0.000000] kvm-clock: using sched offset of 18040739433 cycles
[ 0.000003] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
[ 0.000006] tsc: Detected 2199.998 MHz processor
[ 0.002593] last_pfn = 0x140000 max_arch_pfn = 0x400000000
[ 0.002721] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002736] last_pfn = 0xbffdf max_arch_pfn = 0x400000000
[ 0.009903] found SMP MP-table at [mem 0x000f6370-0x000f637f]
[ 0.010018] Using GB pages for direct mapping
[ 0.010879] RAMDISK: [mem 0x7eabe000-0x7fffffff]
[ 0.010924] ACPI: Early table checksum verification disabled
[ 0.010996] ACPI: RSDP 0x00000000000F6320 000014 (v00 BOCHS )
[ 0.011002] ACPI: RSDT 0x00000000BFFE12CD 00002C (v01 BOCHS BXPCRSDT 00000001 BXPC 00000001)
[ 0.011010] ACPI: FACP 0x00000000BFFE11C9 000074 (v01 BOCHS BXPCFACP 00000001 BXPC 00000001)
[ 0.011018] ACPI: DSDT 0x00000000BFFDFD00 0014C9 (v01 BOCHS BXPCDSDT 00000001 BXPC 00000001)
[ 0.011022] ACPI: FACS 0x00000000BFFDFCC0 000040
[ 0.011026] ACPI: APIC 0x00000000BFFE123D 000090 (v01 BOCHS BXPCAPIC 00000001 BXPC 00000001)
[ 0.012183] Zone ranges:
[ 0.012186] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.012189] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.012192] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.012194] Movable zone start for each node
[ 0.012195] Early memory node ranges
[ 0.012197] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.012199] node 0: [mem 0x0000000000100000-0x00000000bffdefff]
[ 0.012201] node 0: [mem 0x0000000100000000-0x000000013fffffff]
[ 0.012812] Reserved but unavailable: 98 pages
[ 0.012816] Initmem setup node 0 [mem 0x0000000000001000-0x000000013fffffff]
[ 0.058167] ACPI: PM-Timer IO Port: 0x608
[ 0.058188] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
[ 0.058265] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
[ 0.058269] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.058271] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 high level)
[ 0.058273] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.058276] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 high level)
[ 0.058277] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 high level)
[ 0.058286] Using ACPI (MADT) for SMP configuration information
[ 0.058290] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.058322] [mem 0xc0000000-0xfeffbfff] available for PCI devices
[ 0.058324] Booting paravirtualized kernel on KVM
[ 0.058328] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.144235] random: get_random_bytes called from 0xffffffff90b3aa65 with crng_init=0
[ 0.144245] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:4 nr_node_ids:1
[ 0.145057] percpu: Embedded 43 pages/cpu s137304 r8192 d30632 u524288
[ 0.145105] KVM setup async PF for cpu 0
[ 0.145122] kvm-stealtime: cpu 0, msr 13ba161c0
[ 0.145136] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes)
[ 0.145141] Built 1 zonelists, mobility grouping on. Total pages: 1032040
[ 0.145144] Kernel command line: BOOT_IMAGE=/live/vmlinuz boot=live components hostname=vyos username=live nopersistence noautologin nonetworking union=overlay console=ttyS0,115200 console=tty0 initrd=/live/initrd.img
[ 0.146566] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.147114] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.179554] Memory: 4015000K/4193780K available (8204K kernel code, 650K rwdata, 1516K rodata, 1120K init, 1836K bss, 178780K reserved, 0K cma-reserved)
[ 0.180199] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.180208] Kernel/User page tables isolation: enabled
[ 0.190889] rcu: Hierarchical RCU implementation.
[ 0.190894] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.190896] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.190933] NR_IRQS: 16640, nr_irqs: 456, preallocated irqs: 16
[ 0.219823] Console: colour VGA+ 80x25
[ 0.277885] console [tty0] enabled
[ 0.710899] console [ttyS0] enabled
[ 0.714687] ACPI: Core revision 20180810
[ 0.718225] APIC: Switch to symmetric I/O mode setup
[ 0.722993] x2apic enabled
[ 0.726495] Switched APIC routing to physical x2apic.
[ 0.733279] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.737524] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fb63109b96, max_idle_ns: 440795265316 ns
[ 0.745528] Calibrating delay loop (skipped) preset value… 4399.99 BogoMIPS (lpj=8799992)
[ 0.753517] pid_max: default: 32768 minimum: 301
[ 0.757566] Security Framework initialized
[ 0.761558] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.765530] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.770080] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.773517] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.777522] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.789519] Spectre V2 : Mitigation: Full generic retpoline
[ 0.793516] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.801515] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.809534] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.817518] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.825559] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.829516] TAA: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.842282] Freeing SMP alternatives memory: 20K
[ 0.847907] smpboot: CPU0: Intel Xeon Processor (Skylake, IBRS) (family: 0x6, model: 0x55, stepping: 0x4)
[ 0.849657] Performance Events: unsupported p6 CPU model 85 no PMU driver, software events only.
[ 0.853586] rcu: Hierarchical SRCU implementation.
[ 0.858020] NMI watchdog: Perf NMI watchdog permanently disabled
[ 0.861661] smp: Bringing up secondary CPUs …
[ 0.865677] x86: Booting SMP configuration:
[ 0.869529] … node #0, CPUs: #1
[ 0.534395] kvm-clock: cpu 1, msr 66053041, secondary cpu clock
[ 0.877558] KVM setup async PF for cpu 1
[ 0.881509] kvm-stealtime: cpu 1, msr 13ba961c0
[ 0.885650] #2
[ 0.534395] kvm-clock: cpu 2, msr 66053081, secondary cpu clock
[ 0.889550] KVM setup async PF for cpu 2
[ 0.893509] kvm-stealtime: cpu 2, msr 13bb161c0
[ 0.897658] #3
[ 0.534395] kvm-clock: cpu 3, msr 660530c1, secondary cpu clock
[ 0.905550] KVM setup async PF for cpu 3
[ 0.909509] kvm-stealtime: cpu 3, msr 13bb961c0
[ 0.913529] smp: Brought up 1 node, 4 CPUs
[ 0.917518] smpboot: Max logical packages: 4
[ 0.920664] smpboot: Total of 4 processors activated (17599.98 BogoMIPS)
[ 0.922362] devtmpfs: initialized
[ 0.925579] x86/mm: Memory block size: 128MB
[ 0.929572] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.933523] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.937653] pinctrl core: initialized pinctrl subsystem
[ 0.943201] NET: Registered protocol family 16
[ 0.945632] audit: initializing netlink subsys (disabled)
[ 0.949591] audit: type=2000 audit(1573850183.493:1): state=initialized audit_enabled=0 res=1
[ 0.953533] cpuidle: using governor ladder
[ 0.957558] cpuidle: using governor menu
[ 0.961859] ACPI: bus type PCI registered
[ 0.965517] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.969594] dca service started, version 1.12.1
[ 0.973755] PCI: Using configuration type 1 for base access
[ 0.978679] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.981524] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.985626] ACPI: Added _OSI(Module Device)
[ 0.988577] ACPI: Added _OSI(Processor Device)
[ 0.989540] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.993533] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.997519] ACPI: Added _OSI(Linux-Dell-Video)
[ 1.001307] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 1.002103] ACPI: 1 ACPI AML tables successfully acquired and loaded
[ 1.006981] ACPI: Interpreter enabled
[ 1.009527] ACPI: (supports S0 S5)
[ 1.012231] ACPI: Using IOAPIC for interrupt routing
[ 1.013537] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 1.017647] ACPI: Enabled 2 GPEs in block 00 to 0F
[ 1.023150] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 1.025525] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI]
[ 1.029525] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 1.033528] acpi PNP0A03:00: fail to add MMCONFIG information, can’t access extended PCI configuration space under this bridge.
[ 1.037901] acpiphp: Slot [3] registered
[ 1.040941] acpiphp: Slot [4] registered
[ 1.041584] acpiphp: Slot [5] registered
[ 1.044625] acpiphp: Slot [6] registered
[ 1.045573] acpiphp: Slot [7] registered
[ 1.049667] acpiphp: Slot [8] registered
[ 1.053592] acpiphp: Slot [9] registered
[ 1.056690] acpiphp: Slot [10] registered
[ 1.057659] acpiphp: Slot [11] registered
[ 1.061642] acpiphp: Slot [12] registered
[ 1.065663] acpiphp: Slot [13] registered
[ 1.069611] acpiphp: Slot [14] registered
[ 1.073028] acpiphp: Slot [15] registered
[ 1.073583] acpiphp: Slot [16] registered
[ 1.076832] acpiphp: Slot [17] registered
[ 1.077760] acpiphp: Slot [18] registered
[ 1.081631] acpiphp: Slot [19] registered
[ 1.085569] acpiphp: Slot [20] registered
[ 1.088405] acpiphp: Slot [21] registered
[ 1.089582] acpiphp: Slot [22] registered
[ 1.092491] acpiphp: Slot [23] registered
[ 1.093641] acpiphp: Slot [24] registered
[ 1.097421] acpiphp: Slot [25] registered
[ 1.097597] acpiphp: Slot [26] registered
[ 1.101091] acpiphp: Slot [27] registered
[ 1.101571] acpiphp: Slot [28] registered
[ 1.105609] acpiphp: Slot [29] registered
[ 1.109491] acpiphp: Slot [30] registered
[ 1.109609] acpiphp: Slot [31] registered
[ 1.113364] PCI host bridge to bus 0000:00
[ 1.113518] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 1.117516] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 1.121520] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 1.125519] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff window]
[ 1.129517] pci_bus 0000:00: root bus resource [mem 0x140000000-0x1bfffffff window]
[ 1.133517] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.141743] pci 0000:00:01.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 1.145517] pci 0000:00:01.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 1.149517] pci 0000:00:01.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 1.153517] pci 0000:00:01.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 1.162156] pci 0000:00:01.3: quirk: [io 0x0600-0x063f] claimed by PIIX4 ACPI
[ 1.165536] pci 0000:00:01.3: quirk: [io 0x0700-0x070f] claimed by PIIX4 SMB
[ 1.194491] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10 11)
[ 1.197639] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 *10 11)
[ 1.201905] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10 *11)
[ 1.205806] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10 *11)
[ 1.209626] ACPI: PCI Interrupt Link [LNKS] (IRQs *9)
[ 1.214036] ACPI: bus type USB registered
[ 1.217586] usbcore: registered new interface driver usbfs
[ 1.221543] usbcore: registered new interface driver hub
[ 1.225560] usbcore: registered new device driver usb
[ 1.229438] pps_core: LinuxPPS API ver. 1 registered
[ 1.229517] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 1.233530] PTP clock support registered
[ 1.236739] EDAC MC: Ver: 3.0.0
[ 1.237855] PCI: Using ACPI for IRQ routing
[ 1.241689] clocksource: Switched to clocksource kvm-clock
[ 1.245856] pnp: PnP ACPI init
[ 1.248807] pnp: PnP ACPI: found 5 devices
[ 1.260698] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.266807] NET: Registered protocol family 2
[ 1.271530] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 1.278904] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.283971] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.288629] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.292688] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.296494] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.300922] NET: Registered protocol family 1
[ 1.304666] pci 0000:00:01.0: PIIX3: Enabling Passive Release
[ 1.309430] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[ 1.315444] pci 0000:00:01.0: Activating ISA DMA hang workarounds
[ 1.345588] PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 1.379477] pci 0000:00:01.2: 0xffffffff90050330 took 57297 usecs
[ 1.384182] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 1.390456] Unpacking initramfs…
[ 1.806262] Freeing initrd memory: 21768K
[ 1.810227] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.816459] software IO TLB: mapped [mem 0xbbfdf000-0xbffdf000] (64MB)
[ 1.821095] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fb63109b96, max_idle_ns: 440795265316 ns
[ 1.830184] Initialise system trusted keyrings
[ 1.836560] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 2.309152] Key type asymmetric registered
[ 2.314880] Asymmetric key parser ‘x509’ registered
[ 2.321352] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 2.332880] io scheduler noop registered
[ 2.338223] io scheduler deadline registered
[ 2.343401] io scheduler cfq registered (default)
[ 2.349685] io scheduler mq-deadline registered
[ 2.356711] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 2.364756] ioatdma: Intel(R) QuickData Technology Driver 4.00
[ 2.373495] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.411736] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 2.421184] AMD IOMMUv2 driver by Joerg Roedel [email protected]
[ 2.428116] AMD IOMMUv2 functionality not available on this system
[ 2.436721] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 2.447504] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.453756] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.459797] rtc_cmos 00:00: RTC can wake from S4
[ 2.466249] rtc_cmos 00:00: registered as rtc0
[ 2.472186] rtc_cmos 00:00: alarms up to one day, y3k, 114 bytes nvram
[ 2.480102] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.487300] NET: Registered protocol family 10
[ 2.493251] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 2.512159] Segment Routing with IPv6
[ 2.515366] mip6: Mobile IPv6
[ 2.519411] mce: Using 10 MCE banks
[ 2.523147] sched_clock: Marking stable (1992678206, 530395921)->(2723194380, -200120253)
[ 2.533061] registered taskstats version 1
[ 2.538124] Loading compiled-in X.509 certificates
[ 2.544225] rtc_cmos 00:00: setting system clock to 2019-11-15 20:36:25 UTC (1573850185)
[ 2.980431] Freeing unused kernel image memory: 1120K
[ 3.001607] Write protecting the kernel read-only data: 12288k
[ 3.015618] Freeing unused kernel image memory: 2028K
[ 3.021045] Freeing unused kernel image memory: 532K
[ 3.044427] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 3.052744] x86/mm: Checking user space page tables
[ 3.075449] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 3.087187] Run /init as init process
[ 3.107278] systemd-udevd[96]: starting version 215
[ 3.112499] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 3.193884] piix4_smbus 0000:00:01.3: SMBus Host Controller at 0x700, revision 0
[ 3.258628] SCSI subsystem initialized
[ 3.258983] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.278651] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.341674] scsi host0: ata_piix
[ 3.347113] scsi host1: ata_piix
[ 3.350259] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xc080 irq 14
[ 3.355874] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xc088 irq 15
[ 3.360272] PCI Interrupt Link [LNKC] enabled at IRQ 10
[ 3.365857] uhci_hcd 0000:00:01.2: UHCI Host Controller
[ 3.370553] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
[ 3.379297] uhci_hcd 0000:00:01.2: detected 2 ports
[ 3.383787] uhci_hcd 0000:00:01.2: irq 11, io base 0x0000c040
[ 3.388297] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 3.396741] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.403100] usb usb1: Product: UHCI Host Controller
[ 3.409139] usb usb1: Manufacturer: Linux 4.19.84-amd64-vyos uhci_hcd
[ 3.415582] usb usb1: SerialNumber: 0000:00:01.2
[ 3.419760] hub 1-0:1.0: USB hub found
[ 3.423143] hub 1-0:1.0: 2 ports detected
[ 3.523458] ata1.00: ATAPI: QEMU DVD-ROM, 2.5+, max UDMA/100
[ 3.534049] scsi 0:0:0:0: CD-ROM QEMU QEMU DVD-ROM 2.5+ PQ: 0 ANSI: 5
[ 3.562518] sr 0:0:0:0: [sr0] scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
[ 3.569585] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.765629] usb 1-1: new full-speed USB device number 2 using uhci_hcd
[ 3.919064] loop: module loaded
[ 3.950465] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
[ 3.958041] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=5
[ 3.963378] usb 1-1: Product: QEMU USB Tablet
[ 3.967810] usb 1-1: Manufacturer: QEMU
[ 3.970284] usb 1-1: SerialNumber: 42
[ 3.975175] random: fast init done
[ 3.981553] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.990125] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.994934] usbcore: registered new interface driver usbhid
[ 4.001085] usbhid: USB HID core driver
[ 4.010896] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input3
[ 4.043308] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:01.2-1/input0
[ 4.570149] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.580537] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 4.590162] systemd[1]: Detected virtualization ‘kvm’.
[ 4.594192] systemd[1]: Detected architecture ‘x86-64’.
[ 4.680040] systemd[1]: Inserted module ‘autofs4’
[ 4.689531] systemd[1]: Set hostname to <localhost.localdomain>.
[ 4.694994] systemd[1]: Initializing machine ID from KVM UUID.
[ 4.831338] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 5.215962] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 5.458609] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 5.473900] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 5.482023] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.491314] systemd[1]: Expecting device dev-ttyS0.device…
[ 10.839071] systemd-udevd[489]: starting version 215
[ 11.182855] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 11.190462] ACPI: Power Button [PWRF]
[ 11.506486] cryptd: max_cpu_qlen set to 1000
[ 11.544038] systemd-journald[327]: Received request to flush runtime journal from PID 1
[ 11.746097] AVX2 version of gcm_enc/dec engaged.
[ 11.751019] AES CTR mode by8 optimization enabled
[ 11.877007] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 11.914666] alg: No test for pcbc(aes) (pcbc-aes-aesni)
[ 11.967236] Bridge firewalling registered
[ 12.049084] fuse init (API version 7.27)
[ 34.903146] eth0: mtu greater than device maximum
[ 34.908810] eth0: mtu greater than device maximum
Welcome to VyOS - vyos-2 ttyS0
vyos-2 login:
