Error: Radius-plugin:foreground:common_name is not defined,具体如附件图片
问题:根据radiusplugin.cnf,OpenVPNConfig应该是 “/etc/openvpn/server.conf”,但未有此文件生成,后请人查实,也不是“/run/openvpn/vtun0.conf”,正确的是“/opt/vyatta/config/active/interfaces/openvpn/vtun0/openvpn-option/node.val”,不得所知,官网和其他网上并未查看相关说明文件,能否请看得懂源码的朋友帮忙看看,为何是此目录“/opt/vyatta/config/active/interfaces/openvpn/vtun0/openvpn-option/node.val”
Version:VyOS 1.4-rolling-202101281254
Config:
vyos@vyos#show
openvpn vtun0 {
mode server
openvpn-option --persist-key
openvpn-option --persist-tun
openvpn-option --duplicate-cn
openvpn-option “–plugin /usr/lib/openvpn/radiusplugin.so /config/auth/radiusplugin.cnf”
protocol tcp-passive
tls {
ca-cert-file /config/auth/ca.crt
cert-file /config/auth/central.crt
dh-file /config/auth/dh.pem
key-file /config/auth/central.key
nat { source { rule 1001 { outbound-interface eth0 source { address 192.168.0.0/16 } translation { address masquerade } } } }
protocols { static { route 0.0.0.0/0 { next-hop 10.2.2.254 { } } } }
vyos@vyos# sudo cat /config/auth/radiusplugin.cnf
#OpenVPNConfig=/etc/openvpn/server.conf
#OpenVPNConfig=/run/openvpn/vtun0.conf
OpenVPNConfig=/opt/vyatta/config/active/interfaces/openvpn/vtun0/openvpn-option/node.val
subnet=255.255.255.0
overwriteccfiles=true
vyos@vyos#/run/openvpn/vtun0.conf
verb 3
user openvpn
group openvpn
dev-type tun
dev vtun0
persist-key
iproute /usr/libexec/vyos/system/unpriv-ip
proto tcp-server
mode server
tls-server
topology net30
management /run/openvpn/openvpn-mgmt-intf unix
TLS options
ca /config/auth/ca.crt
cert /config/auth/central.crt
key /config/auth/central.key
dh /config/auth/dh.pem
–persist-key
–persist-tun
–duplicate-cn
–log /var/log/openvpn.log
–verb 4
–client-cert-not-required
–username-as-common-name
vyos@vyos#/opt/vyatta/config/active/interfaces/openvpn/vtun0/openvpn-option/node.val
–persist-key
–persist-tun
–duplicate-cn
verb 4
username-as-common-name[edit]
vyos@vyos# ls
client server update-resolv-conf
vyos@vyos# pwd
/etc/openvpn
