I have access to VyOS iso under vyos for education. I am using proxmox now for our lab. I use the iso for installing VyOS. Is the qcow2 image any different? Does it have any particular optimization?
Proxmox VE uses KVM directly, so RAW and QCOW2 conform to KVM’s behavior
the qcow image is a basic image, just as if you installed it from iso. only its installed allready for your benefit.
