Some Windows 7 clients are having trouble to connect our IPSec/IKEV2 VPN server from the LTE (4G) mobile data network. A VyOS router located on the edge of our Autonomous System (AS) is discarding packets marked as fragmented on the WAN interface instead of forwarding them to the VPN server.
As we can see from the capture below, the first two packets exchanged on UDP port 500 are forwarded normally. When the client sends the first fragmented packet destined for UDP port 4500 containing the IKE_AUTH MID = 01 Initiator Request, this packet and subsequent packets are discarded by our VyOS WAN interface.
Capturing the packages on the VyOS WAN interface we can see that tcpdump identifies “len mismatch” (isakmp 1952 / ip 1468) in these packages and for some reason VyOS discards them.
These packets pass through multiple routers in your path but none of them discard packets, only VyOS.
When we route these packets through a Cisco router on another ISP link, the packets are routed to the VPN server and everything works normally.
Does anyone have any idea how to solve this?
Thanks
Capture with packets arriving at the VyOS router WAN:
vyos@MY-VYOS-ROUTER:~$ sudo tcpdump -i eth0 host 179.172.90.90
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
19:09:11.371087 IP 179-172-90-90.user.vivozap.com.br.isakmp > my.vpn.server.isakmp: isakmp: parent_sa ikev2_init[I]
19:09:11.373363 IP my.vpn.server.isakmp > 179-172-90-90.user.vivozap.com.br.isakmp: isakmp: parent_sa ikev2_init[R]
19:09:11.566815 IP 179-172-90-90.user.vivozap.com.br.ipsec-nat-t > my.vpn.server.ipsec-nat-t: NONESP-encap: isakmp: child_sa ikev2_auth[I]
19:09:13.591781 IP 179-172-90-90.user.vivozap.com.br.ipsec-nat-t > my.vpn.server.ipsec-nat-t: NONESP-encap: isakmp: child_sa ikev2_auth[I]
19:09:16.590730 IP 179-172-90-90.user.vivozap.com.br.ipsec-nat-t > my.vpn.server.ipsec-nat-t: NONESP-encap: isakmp: child_sa ikev2_auth[I]
^C
5 packets captured
7 packets received by filter
0 packets dropped by kernel
Capture packets on LAN interface (eth1) showing packets have been dropped
vyos@MY-VYOS-ROUTER:~$ sudo tcpdump -i eth1 host 179.172.90.90
listening on eth1, link-type EN10MB (Ethernet), capture size 262144 bytes
19:09:30.438363 IP 179-172-90-90.user.vivozap.com.br.isakmp > my.vpn.server.isakmp: isakmp: parent_sa ikev2_init[I]
19:09:30.440416 IP my.vpn.server.isakmp > 179-172-90-90.user.vivozap.com.br.isakmp: isakmp: parent_sa ikev2_init[R]
^C
2 packets captured
15 packets received by filter
1 packet dropped by interface
Verbose capture on WAN interface showing more details (len mismatch) of dropped packets:
19:10:16.019806 IP (tos 0x0, ttl 109, id 6742, offset 0, flags [+], proto UDP (17), length 1500)
179-172-90-90.user.vivozap.com.br.ipsec-nat-t > my.vpn.server.ipsec-nat-t: NONESP-encap: isakmp 2.0 msgid 00000001: child_sa ikev2_auth[I]: [|v2e] (len mismatch: isakmp 1952/ip 1468)
19:10:18.013782 IP (tos 0x0, ttl 109, id 6818, offset 0, flags [+], proto UDP (17), length 1500)
19:10:20.023659 IP (tos 0x0, ttl 109, id 6886, offset 0, flags [+], proto UDP (17), length 1500)
VyOS configuration ( VyOS 1.2.3 on Dell PowerEdge 2950)
high-availability {
vrrp {
group eth1-10 {
advertise-interval 1
interface eth1
priority 110
rfc3768-compatibility
virtual-address x.x.x.x/28
vrid 10
address 10.6.5.124/29
description WAN
duplex auto
hw-id 00:1e:4f:19:3d:1c
smp-affinity auto
speed auto
address y.y.y.y/28
description LAN
duplex auto
hw-id 00:1e:4f:19:3d:1e
smp-affinity auto
speed auto
traffic-policy {
out DOWNSTREAM
ethernet eth2 {
duplex auto
hw-id 00:15:17:47:e0:08
smp-affinity auto
speed auto
loopback lo {
address 10.0.0.1/32
policy {
as-path-list AS99999 {
rule 10 {
action permit
regex ^
as-path-list FilterIn-AS88888 {
rule 100 {
action permit
description "Filtra AS-path com tamanho maximo de 4"
regex "^88888(_[0-9]+){0,3}"
prefix-list MEU-BLOCO {
rule 10 {
action permit
prefix Y.Y.Y.0/24
route-map LOCAL-PREF {
rule 100 {
action permit
set {
local-preference 200
route-map MYORG-OUT {
rule 10 {
action permit
match {
ip {
address {
protocols {
bgp 99999 {
address-family {
ipv4-unicast {
network X.X.X.0/24 {
neighbor 10.0.0.2 {
address-family {
ipv4-unicast {
nexthop-self
remote-as 99999
timers {
connect 15
holdtime 30
keepalive 10
update-source lo
neighbor 10.6.5.121 {
address-family {
ipv4-unicast {
filter-list {
export AS99999
import FilterIn-AS88888
route-map {
export MYORG-OUT
remote-as 88888
timers {
holdtime 90
keepalive 30
static {
route 0.0.0.0/0 {
next-hop X.X.X.2 {
distance 25
route 10.0.0.2/32 {
next-hop X.X.X.2 {
route 172.17.1.19/32 {
next-hop X.X.X.6 {
route X.X.X.0/24 {
blackhole {
route X.X.X.64/26 {
next-hop X.X.X.6 {
distance 1
route y.y.y.128/25 {
next-hop X.X.X.6 {
route a.a.a.a/32 {
next-hop x.x.x.2 {
service {
snmp {
community abcde {
authorization ro
client k.k.k.k
network X.X.X.0/24
community public {
authorization ro
client k.k.k.k
network X.X.X.0/24
ssh {
port 22
system {
config-management {
commit-revisions 20
console {
device ttyS0 {
speed 9600
flow-accounting {
interface eth0
netflow {
engine-id 100
server y.y.y.y4 {
port 3001
version 5
syslog-facility daemon
host-name MYROUTER
login {
user vyos {
authentication {
encrypted-password $6$F9xeE2sWNRjL.RSs$h6GF87hszfyiRUq//Z7IK13Enqf3Nslz5PpjFz.
plaintext-password “”
level admin
user nagios {
authentication {
encrypted-password $6$6ZwU3JMhzPNGBo$l/elc1WZdMHDDD8i2ep1Nxet/pnyhKnjCMjIkg6.
full-name “Nagios ssh”
level operator
name-server 8.8.8.8
name-server 1.1.1.1
ntp {
server a.ntp.br {
server b.ntp.br {
server ntp.pop-rs.rnp.br {
prefer
syslog {
global {
facility all {
level notice
facility protocols {
level debug
host 172.17.1.19 {
facility all {
level info
time-zone America/Sao_Paulo
traffic-policy {
shaper DOWNSTREAM {
bandwidth 250Mbit
class 80 {
bandwidth 80%
burst 45k
ceiling 90%
match MONITOR {
description “servicos de monitoramento do link”
ip {
protocol icmp
address m.m.m.m/32
queue-type priority
class 90 {
bandwidth 80%
burst 45k
ceiling 90%
description “Trafego local”
match LOCAL-ETH1 {
ip {
address y.y.y.y/32
queue-type priority
class 100 {
bandwidth 20%
burst 15k
ceiling 30%
description “Rede Wireless”
match WIFI-DOWN {
description “Range Wireless”
ip {
destination {
address x.x.x.7/32
queue-type priority
default {
bandwidth 80%
burst 45k
ceiling 90%
queue-type fair-queue
description “Politica de downstream para o link ISP1”
