Vyos send huge ICMP request
Why vyos sending huge ICMP request to Public IP even no one do ping test to that IP
vyos@R1:~$ sudo tcpdump -n -i eth0 host 210.x.x.x
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
14:29:02.009509 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 41890, length 44
14:29:02.062476 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 42146, length 44
14:29:02.115773 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 42402, length 44
14:29:02.168700 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 42658, length 44
14:29:02.221624 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 42914, length 44
14:29:02.274630 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 43170, length 44
14:29:02.327570 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 43426, length 44
14:29:02.380438 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 43682, length 44
14:29:02.433273 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 43938, length 44
14:29:02.486208 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 44194, length 44
14:29:02.539098 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 44450, length 44
14:29:02.592025 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 44706, length 44
14:29:02.644965 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 44962, length 44
14:29:02.697947 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 45218, length 44
14:29:02.751004 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 45474, length 44
14:29:02.803913 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 45730, length 44
14:29:02.856884 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 45986, length 44
14:29:02.909783 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 46242, length 44
14:29:02.962677 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 46498, length 44
14:29:03.006615 IP 211.x.x.x > 210.x.x.x: ICMP echo request, id 38329, seq 46754, length 44
211 is my ip and 210 is other peer IP. We establised VPN IPsec and recently its down. During troubleshoot I found huge ICMP packet were sent via my Public interface and sometimes its stop.
By huge you mean multiple ICMP echo requests and not large ICMP packets? Length 44 should indicate a 36 byte ICMP packet.
Sorry my mistake. Yes it sending huge ICMP echo request. Is this normal?
VyOS itself does not send any ICMP echo’s
Check your scripts or find which process is sending it, or maybe someone from the LAN network does it.
