i am struggling a little bit to add a proxy to the qemu.yml
any idea how to set the environment: "{{proxy_env}}"
so that can the chroot env can use the proxy for download the packages.
under vars i added the proxy_env:
here is the guide to add a proxy, sounds easy but there is using a -block
anybody have a idea how to set the proxy correct.
https://docs.ansible.com/ansible/2.7/user_guide/playbooks_environment.html
- hosts: qemu
gather_facts: false
connection: local
vars:
vyos_platform: QEMU
vyos_format: qcow2
vyos_qemu_img: /tmp/vyos-{{ vyos_version }}{{ ci_tag | default()
}}-{{vyos_disk_size}}G-qemu.qcow2
vyos_output_img: "{{ vyos_qemu_img }}"
cloud_init: "false"
cloud_init_ds_string: "{{ cloud_init_ds | default('NoCloud,ConfigDrive,None') }}"
cloud_init_ds_list: "{{ cloud_init_ds_string.split(',') }}"
proxy_env:
http_proxy: http://proxy:8080
https_proxy: http://proxy:8080
tasks:
- name: Install cobbler
environment: "{{ proxy_env }}"
block:
- include_role:
name: "{{ roleinputvar }}"
loop:
- install-packages
- download-iso
- mount-iso
- get-version
- create-disk
- setup-root-partition
- install-image
- mount-root-fs
- install-config
- install-grub
- install-persistence-conf
- install-cloud-init-wrapper
- install-guest-agent-wrapper
- install-custom-packages-wrapper
- fstrim
- unmount-pre
- create-pxe-archiveaa
- unmount-all
- qemu-qcow2
- cleanup-ending
- release
loop_control:
loop_var: roleinputvar
rescue:
- include_role:
loop:
- unmount-pre
- unmount-all
loop_control:
