VyOS VPN configuration help
Hello all, I hope someone can help me understanding the following issue.
I have a VyOS configured as here, clients that access through the " peer c.c.c.c " tunnel VPN can reach hosts on 192.168.22.0 net nicely but cannot reach hosts on 192.168.2.0 net even if the VyOS itself ( 192.168.22.210 ) can, using the gateway 192.168.22.254 .
Can someone kindly help me understand why and what should I config to allow reaching the 192.168.2.x hosts?
Thanks!
Hello ludiegu,
You LAN 192.168.2.x is LAN on the current VyOS ?
If yes i don’t see a vyos interface conencted to this LAN, so you can’t route the LAN.
Can you PING 192.168.2.x network on your VyOS ?
Or not Something like that :
Thanks for the reply. My VyOS is not on subnet 192.168.2.x/24, but it can reach it via GW 192.168.22.254, hence I can ping any host on subnet 192.168.2.x/24.
I think you need add a static route on router which manage network 192.168.2.x to reach VPN users.
