Running simple VyOS setup for VXLAN with two VyOS VMs in VMware. Version = VyOS 1.3-rolling-202209301229.
The configuration on router A is:
set interfaces bridge br300 member interface eth1.300
set interfaces bridge br300 member interface vxlan300
set interfaces ethernet eth0 address ‘192.168.1.1/27’
set interfaces ethernet eth1 vif 300
set interfaces vxlan vxlan300 group ‘239.0.0.241’
set interfaces vxlan vxlan300 policy
set interfaces vxlan vxlan300 port ‘4789’
set interfaces vxlan vxlan300 source-interface ‘eth0’
set interfaces vxlan vxlan300 vni ‘10300’
Eth0 is the underlay and Eth1 is just a trunk.
On Router B we have the following, note the eth0 is via L3. Not sure what’s configured on that L3 since we don’t control that.
set interfaces ethernet eth0 address ‘192.168.2.1/27’
set interfaces ethernet eth3 vif 300
In the example below 1.1.1.1 is sourced from Router A and 2.2.2.2 is connected to eth1.300 at Router B.
What we are seeing is a pcap on eth1.300 on Router B shows:
14:36:26.158359 IP 1.1.1.1.1645 > 2.2.2.2.1812: RADIUS, Access-Request (1), id: 0x8f length: 330
14:36:26.429935 IP 2.2.2.2.1812 > 1.1.1.1.1645: RADIUS, Access-Accept (2), id: 0x8f length: 1272
14:36:26.430099 IP 2.2.2.2 > 1.1.1.1: ip-proto-17
14:36:26.495283 IP 1.1.1.1.1645 > 2.2.2.2.1812: RADIUS, Access-Request (1), id: 0x90 length: 369
14:36:26.598975 IP 2.2.2.2.1812 > 1.1.1.1.1645: RADIUS, Access-Accept (2), id: 0x90 length: 328
Pcap on br300 on Router B shows:
14:36:26.158330 IP 1.1.1.1.1645 > 2.2.2.2.1812: RADIUS, Access-Request (1), id: 0x8f length: 330
14:36:26.430099 IP 2.2.2.2.1812 > 1.1.1.1.1645: RADIUS, Access-Accept (2), id: 0x8f length: 1506
14:36:26.495258 IP 1.1.1.1.1645 > 2.2.2.2.1812: RADIUS, Access-Request (1), id: 0x90 length: 369
And pcap on vxlan300 on router B shows:
14:36:26.430140 IP 2.2.2.2 > 1.1.1.1: ip-proto-17
I’m a bit lost here. Any tips what’s going on?
Thanks,
