Hi
I’m using a VyOS 1.4-rolling-202110120918.
Looking for help on setting up a site-to-site with an AWS VPC.
Tunnel is up, but I cannot ping the AWS vti,
no traffic traversing the tunnel, except for bgp requests from the AWS vti, which are sometimes replied to by the vti on the VyOS.
Also I couldnt completely follow the commands bgp commands in the AWS vpn document, because it appears to have changed.
Please can someone help to set me straight?
My current configuration:
set vpn ipsec ike-group vyos-aws-ike-0 lifetime ‘28800’
set vpn ipsec ike-group vyos-aws-ike-0 proposal 1 dh-group ‘2’
set vpn ipsec ike-group vyos-aws-ike-0 proposal 1 encryption ‘aes128’
set vpn ipsec ike-group vyos-aws-ike-0 proposal 1 hash ‘sha1’
set vpn ipsec site-to-site peer authentication mode ‘pre-shared-secret’
set vpn ipsec site-to-site peer authentication pre-shared-secret ‘’
set vpn ipsec site-to-site peer description ‘vyos VPC tunnel 0’
set vpn ipsec site-to-site peer ike-group ‘vyos-aws-ike-0’
set vpn ipsec site-to-site peer local-address ‘’
set vpn ipsec site-to-site peer vti bind ‘vti01’
set vpn ipsec site-to-site peer vti esp-group ‘vyos-aws-esp-0’
set vpn ipsec ipsec-interfaces interface ‘eth2’
set vpn ipsec esp-group vyos-aws-esp-0 compression ‘disable’
set vpn ipsec esp-group vyos-aws-esp-0 lifetime ‘3600’
set vpn ipsec esp-group vyos-aws-esp-0 mode ‘tunnel’
set vpn ipsec esp-group vyos-aws-esp-0 pfs ‘enable’
set vpn ipsec esp-group vyos-aws-esp-0 proposal 1 encryption ‘aes128’
set vpn ipsec esp-group vyos-aws-esp-0 proposal 1 hash ‘sha1’
set vpn ipsec ike-group vyos-aws-ike-0 dead-peer-detection action ‘restart’
set vpn ipsec ike-group vyos-aws-ike-0 dead-peer-detection interval ‘15’
set vpn ipsec ike-group vyos-aws-ike-0 dead-peer-detection timeout ‘30’
set protocols bgp 65000 neighbor 169.254.104.65 remote-as ‘64512’
set protocols bgp 65000 neighbor 169.254.104.65 soft-reconfiguration ‘inbound’
set protocols bgp 65000 neighbor 169.254.104.65 timers holdtime ‘30’
set protocols bgp 65000 neighbor 169.254.104.65 timers keepalive ‘10’
set protocols bgp 65000 network 0.0.0.0/0
The bgp commands are rejected as written, what I actually have is
set protocols bgp address-family ipv4-unicast network 10.200.0.0/16 set protocols bgp local-as '65000' set protocols bgp neighbor 169.254.104.65 address-family ipv4-unicast soft-reconfiguration inbound set protocols bgp neighbor 169.254.104.65 capability set protocols bgp neighbor 169.254.104.65 disable-connected-check set protocols bgp neighbor 169.254.104.65 ebgp-multihop '10' set protocols bgp neighbor 169.254.104.65 remote-as '64512' set protocols bgp neighbor 169.254.104.65 timers holdtime '30' set protocols bgp neighbor 169.254.104.65 timers keepalive '10' set protocols bgp neighbor 169.254.104.65 update-source '169.254.104.66'
Cant ping the AWS vti
# ping 169.254.104.65 PING 169.254.104.65 (169.254.104.65) 56(84) bytes of data. From 169.254.104.66 icmp_seq=1 Destination Host Unreachable From 169.254.104.66 icmp_seq=2 Destination Host Unreachable ^C --- 169.254.104.65 ping statistics --- 2 packets transmitted, 0 received, +2 errors, 100% packet loss, time 1026ms
But there are bgp requests from the AWS side:
# tcpdump -i vti01 tcpdump: verbose output suppressed, use -v[v]... for full protocol decode listening on vti01, link-type RAW (Raw IP), snapshot length 262144 bytes 10:17:48.885995 IP 169.254.104.66.46395 > 169.254.104.65.bgp: Flags [S], seq 1435613076, win 64216, options [mss 1396,sackOK,TS val 1887071169 ecr 0,nop,wscale 7], length 0 10:18:00.606147 IP 169.254.104.65.42681 > 169.254.104.66.bgp: Flags [S], seq 3124765092, win 26880, options [mss 1375,sackOK,TS val 2481240683 ecr 0,nop,wscale 7], length 0 10:18:01.644345 IP 169.254.104.65.42681 > 169.254.104.66.bgp: Flags [S], seq 3124765092, win 26880, options [mss 1375,sackOK,TS val 2481241721 ecr 0,nop,wscale 7], length 0 10:18:03.652778 IP 169.254.104.65.42681 > 169.254.104.66.bgp: Flags [S], seq 3124765092, win 26880, options [mss 1375,sackOK,TS val 2481243730 ecr 0,nop,wscale 7], length 0 ^C 4 packets captured 4 packets received by filter 0 packets dropped by kernel
I also assumed (wrongly?) that I would see bgp here:
# run show bgp No BGP prefixes displayed, 0 exist
Thanks for any advice!
