Hi all,
I would like to use an mellanox network card MT26428 with 2 ports QSFP, but the vyos didn’t up this interface.
Have any drive to use this?
Thanks,
Sidnei
Hi all,
Thanks,
Sidnei
A lot of Mellanox cards won’t show up in Linux until the card+driver knows if it’s supposed to be in Ethernet or Infiniband mode. The easiest way to do this is to plug it into a switch. Odds are once you plug it in, it’ll be visible in VyOS within a couple seconds.
I tried to connect it to a switch, but there was no vyos interface.
Sidnei
Hi @sidnei, can you provide sudo lspci | grep Mellanox.
Check please also cat /sys/bus/pci/devices/0000\:01\:00.0/mlx4_port1, but replace your bus-id
