- I test “L2TP+Radius”,it’s ok;
- I test “PPTP+Localuser”,it’s ok;
- I test “PPTP+Radius”,There is some problem;
the vyos config:
pptp {
remote-access {
authentication {
local-users {
username fei.xue {
password ****************
mode radius
radius-server 10.131.2.13 {
key ****************
require mschap-v2
client-ip-pool {
start 10.131.57.20
stop 10.131.57.220
dns-servers {
server-1 10.131.2.9
outside-address 114.112.84.201
the windows PPTP client:
the error log :
| 2018-12-05 10:49:01 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: MGR: Launching /usr/sbin/pptpctrl to handle client |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: local address = 10.255.254.0 |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: remote address = 10.131.57.20 |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: pppd options file = /etc/ppp/options.pptpd |
| 2018-12-05 10:49:02 | Daemon.Info | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Client 118.186.39.90 control connection started |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Received PPTP Control Message (type: 1) |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Made a START CTRL CONN RPLY packet |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: I wrote 156 bytes to the client. |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Sent packet to client |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Received PPTP Control Message (type: 7) |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Set parameters to 100000000 maxbps, 64 window size |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Made a OUT CALL RPLY packet |
| 2018-12-05 10:49:02 | Daemon.Info | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Starting call (launching pppd, opening GRE) |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: pty_fd = 6 |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: tty_fd = 7 |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: I wrote 32 bytes to the client. |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17561]: CTRL (PPPD Launcher): program binary = /usr/sbin/pppd |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17561]: CTRL (PPPD Launcher): local address = 10.255.254.0 |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17561]: CTRL (PPPD Launcher): remote address = 10.131.57.20 |
| 2018-12-05 10:49:02 | Local2.Info | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: Plugin radius.so loaded. |
| 2018-12-05 10:49:02 | Local2.Info | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: RADIUS plugin initialized. |
| 2018-12-05 10:49:02 | Local2.Info | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: Plugin radattr.so loaded. |
| 2018-12-05 10:49:02 | Local2.Info | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: RADATTR plugin initialized. |
| 2018-12-05 10:49:02 | Local2.Notice | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: pppd 2.4.4 started by root, uid 0 |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: using channel 81 |
| 2018-12-05 10:49:02 | Local7.Info | 10.131.2.39 | Dec 5 10:48:46 vpn39 zebra[2429]: interface ppp0 index 84 <POINTOPOINT,NOARP,MULTICAST> added. |
| 2018-12-05 10:49:02 | Local2.Info | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: Using interface ppp0 |
| 2018-12-05 10:49:02 | Local2.Notice | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: Connect: ppp0 ↔ /dev/pts/1 |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x7778e3d0> ] |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Received PPTP Control Message (type: 15) |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: CTRL: Got a SET LINK INFO packet with standard ACCMs |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: GRE: accepting packet #0 |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: rcvd [LCP ConfReq id=0x0 <mru 1400> <magic 0x14a1d81> ] |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: lcp_reqci: rcvd unknown option 13 |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: lcp_reqci: returning CONFREJ. |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: sent [LCP ConfRej id=0x0 ] |
| 2018-12-05 10:49:02 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pptpd[17559]: GRE: accepting packet #1 |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: rcvd [LCP ConfReq id=0x1 <mru 1400> <magic 0x14a1d81> ] |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: lcp_reqci: returning CONFACK. |
| 2018-12-05 10:49:02 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:46 vpn39 pppd[17561]: sent [LCP ConfAck id=0x1 <mru 1400> <magic 0x14a1d81> ] |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x7778e3d0> ] |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #2 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x7778e3d0> ] |
| 2018-12-05 10:49:05 | Local7.Info | 10.131.2.39 | Dec 5 10:48:49 vpn39 zebra[2429]: interface ppp0 mtu changed from 1500 to 1400 |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Received PPTP Control Message (type: 15) |
| 2018-12-05 10:49:05 | Daemon.Error | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Ignored a SET LINK INFO packet with real ACCMs! |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #3 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: sent [CHAP Challenge id=0x27 , name = “pptpd”] |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #4 |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #5 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [LCP Ident id=0x2 magic=0x14a1d81 “MSRASV5.20”] |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [LCP Ident id=0x3 magic=0x14a1d81 “MSRAS-0-KVM-ADMIN-IP19”] |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [LCP Ident id=0x4 magic=0x14a1d81 “!\37777777764\37777777765z\37777777710\37777777610\021@\37777777627\37777777660\031\37777777634\37777777620\37777777765\37777777725\37777777702”] |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #6 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [CHAP Response id=0x27 , name = “fei.xue”] |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: RADATTR plugin wrote 7 line(s) to file /var/run/radattr.ppp0. |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: sent [CHAP Success id=0x27 “S=CB3ADAC337F4E3B84ACBAF62EAFF264BD14061D3”] |
| 2018-12-05 10:49:05 | Local2.Error | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: MPPE required, but keys are not available. Possible plugin problem? |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: sent [LCP TermReq id=0x2 “MPPE required but not available”] |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #7 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [proto=0x8057] 01 05 00 0e 01 0a a0 8a e5 72 50 9d 81 71 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: Discarded non-LCP packet when LCP not open 0 0 |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #8 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [CCP ConfReq id=0x6 <mppe +H -M -S -L -D -C>] |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #9 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [IPCP ConfReq id=0x7 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-wins 0.0.0.0> <ms-dns3 0.0.0.0> <ms-wins 0.0.0.0>] |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Got a SET LINK INFO packet with standard ACCMs |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: GRE: accepting packet #10 |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: rcvd [LCP TermAck id=0x2 “MPPE required but not available”] |
| 2018-12-05 10:49:05 | Local2.Notice | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: Connection terminated: no multilink. |
| 2018-12-05 10:49:05 | Local2.Info | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: Connect time 0.1 minutes. |
| 2018-12-05 10:49:05 | Local2.Info | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: Sent 0 bytes, received 0 bytes. |
| 2018-12-05 10:49:05 | Local7.Info | 10.131.2.39 | Dec 5 10:48:49 vpn39 zebra[2429]: interface ppp0 index 84 deleted. |
| 2018-12-05 10:49:05 | Local7.Info | 10.131.2.39 | Dec 5 10:48:49 vpn39 ripngd[2433]: interface delete ppp0 index 84 flags 0x1090 metric 1 mtu 1400 |
| 2018-12-05 10:49:05 | Local7.Info | 10.131.2.39 | Dec 5 10:48:49 vpn39 ripd[2431]: interface delete ppp0 index 84 flags 0x1090 metric 1 mtu 1400 |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Received PPTP Control Message (type: 12) |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Made a CALL DISCONNECT RPLY packet |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Received CALL CLR request (closing call) |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Reaping child PPP[17561] |
| 2018-12-05 10:49:05 | Local2.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: RADATTR plugin removed file /var/run/radattr.ppp0. |
| 2018-12-05 10:49:05 | Local2.Info | 10.131.2.39 | Dec 5 10:48:49 vpn39 pppd[17561]: Exit. |
| 2018-12-05 10:49:05 | Daemon.Info | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Client 118.186.39.90 control connection finished |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[17559]: CTRL: Exiting now |
| 2018-12-05 10:49:05 | Daemon.Debug | 10.131.2.39 | Dec 5 10:48:49 vpn39 pptpd[12930]: MGR: Reaped child 17559 |
