Hi all,
I have been having this issue constantly, sometimes it appears to work but i finally figured out its all false, its still load sharing.
End goal: Have internet going over eth0.167 only unless its failed
I will try to simplify my setup but pasted full config too, as I have VRRP at play too on the LAN side, not WAN.
Here is the full config file, apologies for length but its mostly firewall
Version
mario@vyos007:~$ show version
Version: VyOS 1.4-rolling-202202200623
Release train: sagitta
Built by: autobuild@vyos.net
Built on: Sun 20 Feb 2022 06:23 UTC
Build UUID: e70d3f7d-3523-4a8f-af6c-8fe07fc09744
Build commit ID: 7c82c5c7104675
Architecture: x86_64
Boot via: installed image
System type: VMware guest
Hardware vendor: VMware, Inc.
Hardware S/N: VMware-42 1f 29 92 a1 0b 9f a2-cc e7 85 32 d3 2a 7a 9a
Hardware UUID: 92291f42-0ba1-a29f-cce7-8532d32a7a9a
I get internet going by adding a static route to 0.0.0.0 with dhcp-interface eth0.167 but even this is not reliable and its noticable when the 4G internet hasnt been paid as traffic is dropping out. And then defeats having failover at all.
Really appreciate any help please, I must be not seeing something right in front of my nose ![]()
I log all my new connections and can see eth0.197 being constantly used, even tho show wan-load-balance showing it as failed.
My WAN (dhcp cable modem) is on eth0.167, my expensive 4G backup ethernet modem/router is on dhcp eth0.197 and vyos gets a 10.x address from it.
I am not sure what I am doing anymore and whatever happens i am losing connectivity as most traffic is going over eth0.197 that I left the credits lapse. So currently this interface is failing in show wan-load-balance
mario@vyos007:~$ show wan-load-balance
Interface: eth0.167
Status: active
Last Status Change: Mon May 2 17:47:04 2022
+Test: ping Target: 1.0.0.1
Last Interface Success: 0s
Last Interface Failure: n/a
# Interface Failure(s): 0
Interface: eth0.197
Status: failed
Last Status Change: Mon May 2 17:47:24 2022
-Test: ping Target: 1.1.1.1
Last Interface Success: n/a
Last Interface Failure: 0s
# Interface Failure(s): 51
My load-balance configuration
mario@vyos007# show load-balancing
wan {
enable-local-traffic
flush-connections
interface-health eth0.167 {
failure-count 3
nexthop dhcp
success-count 1
test 10 {
resp-time 5
target 1.0.0.1
ttl-limit 1
type ping
interface-health eth0.197 {
failure-count 3
nexthop dhcp
success-count 1
test 10 {
resp-time 5
target 1.1.1.1
ttl-limit 1
type ping
rule 5 {
destination {
address 192.168.0.0/16
exclude
inbound-interface eth+
protocol all
rule 6 {
destination {
address 172.16.0.0/12
exclude
protocol all
rule 7 {
destination {
address 10.0.0.0/8
exclude
protocol all
rule 10 {
failover
inbound-interface eth0.7v7
interface eth0.167 {
weight 10
interface eth0.197 {
weight 1
protocol all
rule 20 {
failover
inbound-interface eth0.11v11
weight 10
weight 1
protocol all
rule 30 {
failover
inbound-interface eth0.13v13
weight 10
weight 1
protocol all
rule 40 {
failover
inbound-interface eth0.17v17
weight 10
weight 1
protocol all
rule 50 {
failover
inbound-interface eth0.67v67
weight 10
weight 1
protocol all
rule 70 {
failover
inbound-interface eth0.131v131
weight 10
weight 1
protocol all
sticky-connections {
inbound
my nat source rules
mario@vyos007# show nat source
rule 5010 {
description "Masquerade for WAN"
outbound-interface eth0.167
translation {
address masquerade
rule 5020 {
description "Masquerade for WAN_BCK"
outbound-interface eth0.197
translation {
address masquerade
I do not have anything in show policy or show protocols worthy of adding here
My route table with above setup
mario@vyos007:~$ sh ip route
f - OpenFabric,
S>* 0.0.0.0/0 [210/0] via 10.73.215.1, eth0.197 onlink, weight 1, 00:01:18
* via 203.7.0.1, eth0.167, weight 1, 00:01:18
S>* 10.73.215.1/32 [1/0] is directly connected, eth0.197, weight 1, 00:01:18
C>* 10.73.215.124/32 is directly connected, eth0.197, 00:00:30
S>* 10.168.17.0/24 [1/0] via 192.168.17.100, eth0.17, weight 1, 00:15:05
S>* 10.168.19.0/24 [1/0] via 192.168.17.100, eth0.17, weight 1, 00:15:05
S>* 192.168.0.0/16 [254/0] unreachable (blackhole), weight 1, 00:15:05
C * 192.168.7.0/24 is directly connected, eth0.7v7, 00:15:01
C>* 192.168.7.0/24 is directly connected, eth0.7, 00:15:14
C * 192.168.11.0/24 is directly connected, eth0.11v11, 00:15:01
C>* 192.168.11.0/24 is directly connected, eth0.11, 00:15:14
C * 192.168.13.0/24 is directly connected, eth0.13v13, 00:15:01
C>* 192.168.13.0/24 is directly connected, eth0.13, 00:15:14
C * 192.168.17.0/24 is directly connected, eth0.17v17, 00:15:01
C>* 192.168.17.0/24 is directly connected, eth0.17, 00:15:14
C * 192.168.53.0/24 is directly connected, eth0.53v53, 00:15:01
C>* 192.168.53.0/24 is directly connected, eth0.53, 00:15:14
C * 192.168.67.0/24 is directly connected, eth0.67v67, 00:15:01
C>* 192.168.67.0/24 is directly connected, eth0.67, 00:15:14
C * 192.168.79.0/24 is directly connected, eth0.79v79, 00:15:01
C>* 192.168.79.0/24 is directly connected, eth0.79, 00:15:14
S>* 192.168.100.0/24 [1/0] is directly connected, eth0.167, weight 1, 00:14:59
C * 192.168.131.0/24 is directly connected, eth0.131v131, 00:15:01
C>* 192.168.131.0/24 is directly connected, eth0.131, 00:15:14
S>* 192.168.197.0/24 [1/0] is directly connected, eth0.197, weight 1, 00:14:58
C>* 203.7.0.0/19 is directly connected, eth0.167, 00:15:12
