wan_lb might have a bug
Update Correction! Not a bug. My error in configuration.
/var/log/messages shows this error every few seconds
vyos wan_lb: failure to insert default route on active path with this command: ip route replace table 202 default dev eth1 via 97.122.107.1
manually entering the command results in error
Error: Nexthop has invalid gateway.
manually adding the parameter ‘onlink’ to the command eliminates the error
ip route replace table 202 default dev eth1 via 97.122.107.1 onlink
version VyOS 1.4-rolling-202211260318
config
set load-balancing wan interface-health eth0 failure-count ‘1’
set load-balancing wan interface-health eth0 nexthop ‘71.157.36.1’
set load-balancing wan interface-health eth0 success-count ‘1’
set load-balancing wan interface-health eth1 failure-count ‘1’
set load-balancing wan interface-health eth1 nexthop ‘98.122.107.1’
set load-balancing wan interface-health eth1 success-count ‘1’
interfaces
eth0 71.157.37.1/22 u/u WAN1
eth1 98.122.103.96/23 u/u WAN2
after adding onlink
ip route show table 202
default via 98.122.107.1 dev eth1 onlink
