WAN Load Balance issue
I have the below wan load balance configuration
set load-balancing wan interface-health eth0 failure-count ‘3’
set load-balancing wan interface-health eth0 nexthop dhcp
set load-balancing wan interface-health eth0 success-count ‘1’
set load-balancing wan interface-health eth0 test 1 target ‘8.8.8.8’
set load-balancing wan interface-health eth0 test 1 type ‘ping’
set load-balancing wan interface-health eth1 failure-count ‘3’
set load-balancing wan interface-health eth1 nexthop dhcp
set load-balancing wan interface-health eth1 success-count ‘1’
set load-balancing wan interface-health eth1 test 1 target ‘8.8.8.8’
set load-balancing wan interface-health eth1 test 1 type ‘ping’
set load-balancing wan rule 10 failover
set load-balancing wan rule 10 inbound-interface ‘any’
set load-balancing wan rule 10 interface eth1
set load-balancing wan rule 20 failover
set load-balancing wan rule 20 inbound-interface ‘any’
set load-balancing wan rule 20 interface eth0
and my goal is to route all the traffic towards eth1, but if eth1 is down then route towards eth0.
But with my current config I see the traffic balances between eth1 and eth0 which is not what I want.
Any idea why?
set load-balancing wan rule 1002 failover
set load-balancing wan rule 1002 inbound-interface 'any'
set load-balancing wan rule 1002 interface eth1 weight '100'
set load-balancing wan rule 1002 interface eht2 weight '99'
set load-balancing wan rule 1002 protocol 'all'
here is an example of one of our loadbalance rules, you can specify multiple interfaces and give a different weight, may also be worth setting your static routes to also use different weights
set protocols static 0.0.0.0/0 via eht1-gateway weight 10
set protocols static 0.0.0.0/0 via eth0-gateway weight 20
Thanks for your reply, but the use of the weight is to split proportionally the traffic.
My concept is eth1 to be used for 100% of the traffic and if it is down then move to eth0.
We utilise the weight of the default route to put all the traffic down primary, then the load-balance wan failover script removes the dead link.
