Wan Load Balancing with DNS forwarding
Hello Board,
I am seeing that when I use WAN load-balancing, my LAN traffic succeeds in moving from one connection to the other when a test fails but my dns forwarding stops working. In testing this is clearly because the dns forwarding process relies on the system’s default route and does not abide by the load-balancing pbr, manually changing my df to my backup connection resolves the issue. Is there any work around for this that anyone has found?
I was hoping not to do this with an OS based cron job.
Thanks,
db
You can use hook scripts.
