Webproxy : multiples problems
I come to ask for help on a freshly installed vyos (and the webproxy service)
Version:          VyOS 1.3.2
Release train:    equuleus
Built by:         Sentrium S.L.
Built on:         Mon 05 Sep 2022 09:23 UTC
Build UUID:       1ceaab3a-4f4e-4692-b551-7c05e1da0a77
Build commit ID:  7ce86511888635
Architecture:     x86_64
Hardware S/N:     VMware-42 29 a8 50 31 92 f7 9e-b0 ad a1 55 bc be 6d 8e
Hardware UUID:    50a82942-9231-9ef7-b0ad-a155bcbe6d8e
The idea is to test the webproxy service in a production environment.
Here is my config
set interfaces ethernet eth0 address 'xxx.xxx.3.2/25'
set interfaces ethernet eth0 hw-id 'xx:xx:xx:xx:xx:30'
set interfaces loopback lo
set protocols static route xxx.xxx.0.0/0 next-hop xxx.xxx.3.1
set service ssh
set service webproxy cache-size '100'
set service webproxy default-port '3128'
set service webproxy domain-block 'monip.org'
set service webproxy listen-address xxx.xxx.3.2 disable-transparent
set service webproxy url-filtering squidguard block-category 'adult'
set service webproxy url-filtering squidguard block-category 'ads'
set service webproxy url-filtering squidguard block-category 'porn'
set service webproxy url-filtering squidguard block-category 'gambling'
set service webproxy url-filtering squidguard block-category 'games'
set service webproxy url-filtering squidguard block-category 'malware'
set service webproxy url-filtering squidguard default-action 'block'
set service webproxy url-filtering squidguard local-block 'monip.org'
set system host-name xxxxxx
set system name-server 'xxx.xxx.0.98'
set system name-server 'xxx.xxx.0.99'
set system ntp server xxxxx.tld
set system syslog global facility all level 'notice'
set system time-zone 'Europe/Paris'
I’ve multiples problems :
  1. I’ve this error message each time than i make a modification in url-filtering
vyos@myvyos# set service webproxy url-filtering squidguard block-category 'malware'
ls: cannot access '/opt/vyatta/etc/config/url-filtering/squidguard/db//*': Permission denied
Nevertheless, the parameter seems to pass
I’m not sur than squidguard is correctly started. I’ve this message at each squidguard restart
`2022-11-18 12:12:02 [17690] init urllist /opt/vyatta/etc/config/url-filtering/squidguard/db/gambling/urls
2022-11-18 12:12:02 [17690] init domainlist /opt/vyatta/etc/config/url-filtering/squidguard/db/games/domains
2022-11-18 12:12:02 [17690] init urllist /opt/vyatta/etc/config/url-filtering/squidguard/db/games/urls
2022-11-18 12:12:03 [17690] init domainlist /opt/vyatta/etc/config/url-filtering/squidguard/db/malware/domains
2022-11-18 12:12:04 [17690] init urllist /opt/vyatta/etc/config/url-filtering/squidguard/db/malware/urls
2022-11-18 12:12:04 [17690] init expressionlist /opt/vyatta/etc/config/url-filtering/squidguard/db/malware/expressions
2022-11-18 12:12:04 [17690] (squidGuard): FATAL: ACL destination local-ok-default is not defined in configfile /etc/squidguard/squidGuard.conf
2022-11-18 12:12:04 [17690] ERROR: Going into emergency mode
2022-11-18 12:13:12 [17727] FATAL: sgDbLoadTextFile: put: Input/output error
2022-11-18 12:13:12 [17727] ERROR: Going into emergency mode
2022-11-18 12:13:12 [17726] FATAL: sgDbLoadTextFile: put: Input/output error
2022-11-18 12:13:12 [17726] ERROR: Going into emergency mode
2022-11-18 12:21:44 [17726] ERROR: Ending emergency mode, stdin empty
2022-11-18 12:21:44 [17727] ERROR: Ending emergency mode, stdin empty
2022-11-18 12:21:44 [17690] ERROR: Ending emergency mode, stdin empty`
I precise than after each restart of webproxy service, i could not use it for a few minutes (a curl is waiting for response and show empty response)
You can see than i try to block monip.org domain. But, a curl monip.org works.
have you encountered the same problems ?
Please contact support,
it seems you use official image
