Most of the match rules results in:
returned (err):
Illegal "match"
[[qos]] failed
Commit failed
I’ve tried to setup simplest config I can imagine to be successfully committed.
Here it is:
vyos@host# show qos
interface eth3 {
egress TEST
policy {
shaper TEST {
bandwidth 61mbit
class 100 {
bandwidth 12mbit
default {
bandwidth 20mbit
But if I try to add simple match like:
set qos policy shaper TEST class 100 match TESTMATCH ip protocol udp
so we have:
vyos@host# show qos policy shaper TEST
bandwidth 61mbit
class 100 {
bandwidth 12mbit
+ match TESTMATCH {
+ ip {
+ protocol udp
default {
bandwidth 20mbit
Than commit returns:
Built on: Tue 21 Mar 2023 15:23 UTC
Build UUID: 6aff375b-d17f-412b-8ca5-c2243173e3e3
Build commit ID: 4eda689e1fbc52
Architecture: x86_64
Boot via: installed image
System type: guest
File "/usr/libexec/vyos/conf_mode/qos.py", line 271, in <module>
apply(c)
File "/usr/libexec/vyos/conf_mode/qos.py", line 260, in apply
tmp.update(shaper_config, direction)
File "/usr/lib/python3/dist-packages/vyos/qos/trafficshaper.py", line 100, in update
super().update(config, direction)
File "/usr/lib/python3/dist-packages/vyos/qos/base.py", line 266, in update
self._cmd(filter_cmd)
File "/usr/lib/python3/dist-packages/vyos/qos/base.py", line 36, in _cmd
return cmd(command)
File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
raise OSError(code, feedback)
PermissionError: [Errno 1] failed to run command: tc filter replace dev eth3 parent 1: protocol all u32 match ip protocol udp 0xff action police rate 12000000 burst 15k flowid 1:64
returned:
exit code: 1
noteworthy:
cmd 'tc qdisc del dev lo parent ffff:'
returned (out):
returned (err):
Error: Cannot find specified qdisc on specified device.
cmd 'tc qdisc del dev lo root'
returned (out):
returned (err):
Error: Cannot delete qdisc with handle of zero.
cmd 'tc qdisc del dev eth0 parent ffff:'
returned (out):
returned (err):
cmd 'tc qdisc del dev eth0 root'
returned (out):
returned (err):
cmd 'tc qdisc del dev eth1 parent ffff:'
returned (out):
returned (err):
cmd 'tc qdisc del dev eth1 root'
returned (out):
returned (err):
cmd 'tc qdisc del dev eth2 parent ffff:'
returned (out):
returned (err):
cmd 'tc qdisc del dev eth2 root'
returned (out):
returned (err):
cmd 'tc qdisc del dev eth3 parent ffff:'
returned (out):
returned (err):
cmd 'tc qdisc del dev wg01 parent ffff:'
returned (out):
returned (err):
cmd 'tc qdisc del dev wg01 root'
returned (out):
returned (err):
cmd 'tc filter replace dev eth3 parent 1: protocol all u32 match ip protocol udp 0xff action police rate 12000000 burst 15k flowid 1:64'
returned (out):
returned (err):
Illegal "match"
[[qos]] failed
Commit failed
Am I doing something wrong or it is a bug?
