What routes should I add in my scenario?
Hi Team.
In my below scenario I would like create four tunnels between R1 and R3
i.e
  • 10.10.10.100 <=> 10.10.30.100
  • 10.10.10.100 <=> 10.10.40.100
  • 10.10.20.100 <=> 10.10.30.100
  • 10.10.20.100 <=> 10.10.40.100
Well I am mimicking the scenario in my home lab. Here R2 can consider as Internet.
Now my query is
And then same scenario with R1 ISP links
Can someone please advise!
Can I use interface name with two default gateways? Will that solve my purpose?
set protocols static route 0.0.0.0/0 next-hop 10.10.10.200 interface eth0
set protocols static route 0.0.0.0/0 next-hop 10.10.20.200 interface eth1
Maybe you can try OSPF dynamic routing will be easier. It can dynamicially found the routing by OSPF.
I agree OSPF is better but I am wondering about my next hops of my ISP. Can I add two default gateways on my vyos router? So that other link can reach to other peer IP address through Internet?
Use this as starting point:
https://docs.vyos.io/en/equuleus/configuration/policy/index.html
And get used to the idea of having multiple routing tables.
Thanks let me try doing that.
So probably local-route could be my solution. But let me test that out in my lab environment and revert.
And thanks again for the pointer.
Something is wrong or not sure I am not able to understad. In my same case for which I uploaded my diagram above. I created tables and applied default gateways
R1
set policy local-route rule 100 set table '100'
set policy local-route rule 100 source '10.10.10.100'
set policy local-route rule 150 set table '150'
set policy local-route rule 150 source '10.10.20.100'
set protocols static table 100 route 0.0.0.0/0 next-hop 10.10.10.200
set protocols static table 150 route 0.0.0.0/0 next-hop 10.10.20.200
And on R3
set policy local-route rule 100 source '10.10.30.100'
set policy local-route rule 150 source '10.10.40.100'
set protocols static table 100 route 0.0.0.0/0 next-hop 10.10.30.200
set protocols static table 150 route 0.0.0.0/0 next-hop 10.10.40.200
Now I try to ping 10.10.30.100 from R1
vyos@R1# ping 10.10.40.100
ping: connect: Network is unreachable
vyos@R1# ^C
vyos@R1# ping 10.10.30.100
vyos@R1#
And from R3
vyos@R3# ping 10.10.10.100
vyos@R3# ping 10.10.20.100
So in this case if the default gateway is added then I guess I should be able to ping other router interfaces?
I dont see routes are installed on my routing table.
vyos@R3# run show ip route
       f - OpenFabric,
C>* 10.10.30.0/24 is directly connected, eth0, 00:29:40
C>* 10.10.40.0/24 is directly connected, eth2, 00:29:39
C>* 169.254.1.0/30 is directly connected, vti1, 00:10:46
C>* 169.254.2.0/30 is directly connected, vti2, 00:29:38
C>* 192.168.30.0/24 is directly connected, eth1, 00:29:40
While table does apper
vyos@R1# run show ip route table 100
       f - OpenFabric,
VRF default table 100:
S>* 0.0.0.0/0 [1/0] via 10.10.10.200, eth0, weight 1, 00:17:29
vyos@R1# run show ip route table 150
       f - OpenFabric,
VRF default table 150:
S>* 0.0.0.0/0 [1/0] via 10.10.20.200, eth1, weight 1, 00:17:32
vyos@R1#
you need to add static routing line by line in each router. if you perfer to static routing. 0.0.0.0/0 is not enough, I thought.
Then PBR local-route will not take effect? What if I need to configure two tunnels from two different ISP providers using their ISP IP addresses?
What source IP is being used?
if it isn’t ‘10.10.10.100’ or '10.10.20.100 , then PBR rules won’t kick in, you fall back to main table which has no default route.
Add /24 routes for connected subnets on eth0 and eth1 too
When I am pinging from R1 or R3 obviously egress interfaces will be used, right? That means traffic will go out using 10.10.10.100 and 10.10.20.100
Aloha,
What is problem you are trying to solve?
I dont get it from you drawing
:sweat_smile:
Uusally on a NOS you can have the same route, poiting to different next-hops,
which will result in form of load-balancing.
I personally woould never use policy routing,
and static routing is maybe in the beginning more easier to create,
but ith a dynamic routing protocol, once its setup, life is much more easy.
:slight_smile:
Cheers
Marcel
I understand, and the issue I am attempting to address is the need to establish four tunnels, with two originating from each Internet Service Provider (ISP). However, I am currently pondering how to incorporate routes while taking into account that R2 serves as the internet gateway.
To provide further context, R1 represents my current location, while R3 denotes the remote location. It is important to note that only a single default gateway can be added.
I trust this clarifies any uncertainties.
Why not ospf and bgp or vrrp ?
For me not
:slight_smile:
Let me go one Step back
So you have a router R1
  • This router will be or is connected to 2 ISP?
  • 2 different ISP with differen AS or same ISP?
  • What do you mean you have to connect through a tunnel to the ISP?
  • You use in your example R2 to simulate one ISP?
As I tried to expliabn, you can configure multipe default routes with different NH.
question does it make sense?
If the cost are the same, normally a router would do Load-balancing over 2 equal-cost-path (ECMP)
Also when you use static routes, you always need to configure both directions, a static route is unidirectional.
Cheers
Marcel
Will the tunnel destinations be static at the remote site? If so, a simple solution is to just do static routes for those specific /32 routes instead of a default.
Here are you answers of your questions -
R2 is just to mimic the ISP.
I have configured 2 links on R1 which are two different ISPs connected to R2
As I said above I have two ISps terminated on Vyos
@blason
Normally egress interface IP is used as source IP. But main table has no route to destination.
The scenario I mentioned can not be achieved. Since VTI is created over IPsec if I try to create one more tunnel from R1 to R3. It gets overwritten the existing one.
I.e. If I have two tunnels ready
10.10.10.100 <==> 10.10.30.100
And
10.10.20.100 <==> 10.10.40.100
And If I try to create tunnel with
10.10.10.100 <==> 10.10.40.100
It gets overwritten with 10.10.20.100 and not able to create one more backup VPN tunnel as such
