When i use docker to build arm64 ISO for the current branch,there are something wrong
1.install Docker
2. Pull image
docker pull vyos/vyos-build:current-arm64
3. create image
git clone -b current --single-branch https://github.com/vyos/vyos-build
cd vyos-build
docker run --rm -it --privileged -v $(pwd):/vyos -w /vyos vyos/vyos-build:current-arm64 bash
start
sudo make clean
sudo ./build-vyos-image --architecture arm64 --build-by "admin@noc.im" generic --debian-mirror "http://deb.debian.org/debian" --debian-security-mirror "http://security.debian.org/" --vyos-mirror "http://dev.packages.vyos.net/repo" --debug
error fix
apt update
apt install -y python3-cracklib kpartx
but there some new bug show
Reading package lists... Done
Package vyos-1x is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Unable to locate package linux-image-6.6.79-vyos
E: Couldn't find any package by glob 'linux-image-6.6.79-vyos'
E: Couldn't find any package by regex 'linux-image-6.6.79-vyos'
E: Package 'vyos-1x' has no installation candidate
P: Saving caches...
vyos-1x and linux-image-6.6.79-vyos can not be find
what i do can fix this?
AFAIK vyos-1x is build as part of the regular image building process, you can look up the repo in the build output folder. Either it has no build target for ARM64 and is skipped (without error) somehow, causing the failure later when it gets relevant or the ARM64 build pipeline is having issues and fails (again without error).
The kernel might indeed not be prebuilt for ARM, causing apt to fail the lookup. No idea on how to proceed with that.
Here are some old notes I have using Docker to build VyOS, probably no longer valid:
  1. Build the vyox-1x debian packages (.deb) by entering the vyos-1x folder and execute (while in docker):
cd /vyos/vyos-1x
time dpkg-buildpackage -uc -us -tc -b
  1. Move the .deb files created to vyos-build/packages directory:
mv /vyos/*.deb /vyos/vyos-build/packages/
So I would assume something similar would apply to this thread aswell?
That is build vyos-1x and current linux-image yourself (if it no longer can be fetched from vyos repos) and then move the deb packages into /vyos/vyos-build/packages/ before you continue your build.
Step 6 was to cd into /vyos/vyos-build and then run ./build-vyos-image with proper syntax to make it either do a smoke-test build and run tests or compile the “release” iso-file to be used as install media (or to upgrade an already existing installation).
I managed to build a arm64 iso and can successfully boot it with VMware Fusion on Apple Silicon.
Things I struggled the most with were:
  • Outdated VyOS docs for building the ISO
  • Outdated container vyos/vyos-build:current-arm64
  • Where do VyOS dependencies live (some are on Git some are local)
  • Missing build dependencies to build the packages
  • OCaml and OPAM dependency issues
After tackling these issues, the build process becomes straightforward.
I created a repo with my Makefile and scripts here: GitHub - yunzheng/vyos-arm64-iso: Helper scripts to build a VyOS arm64 ISO
Hope this helps others!
