Why there are so many sas are being created?
Hi Team,
Any idea with version 1.4.2 why so many SAs are being created?
vyos@R1:~$ show vpn ipsec sa
Connection             State    Uptime    Bytes In/Out    Packets In/Out    Remote address    Remote ID     Proposal
peer_10-10-30-100_vti  down     1s        0B/0B           0B/0B             10.10.30.100      10.10.30.100  AES_CBC_256/HMAC_SHA2_256_128/MODP_1536
peer_10-10-30-100_vti  down     2s        0B/0B           0B/0B             10.10.30.100      10.10.30.100  AES_CBC_256/HMAC_SHA2_256_128/MODP_1536
peer_10-10-30-100_vti  down     3s        0B/0B           0B/0B             10.10.30.100      10.10.30.100  AES_CBC_256/HMAC_SHA2_256_128/MODP_1536
peer_10-10-30-100_vti  down     4s        0B/0B           0B/0B             10.10.30.100      10.10.30.100  AES_CBC_256/HMAC_SHA2_256_128/MODP_1536
peer_10-10-30-100_vti  down     5s        0B/0B           0B/0B             10.10.30.100      10.10.30.100  AES_CBC_256/HMAC_SHA2_256_128/MODP_1536
peer_10-10-30-100_vti  down     6s        0B/0B           0B/0B             10.10.30.100      10.10.30.100  AES_CBC_256/HMAC_SHA2_256_128/MODP_1536
peer_10-10-30-100_vti  up       1s        0B/0B           0B/0B             10.10.30.100      10.10.30.100  AES_CBC_256/HMAC_SHA2_256_128/MODP_1536
vyos@R1:~$
could you please share your configuration,
do that with `show configuration commands | strip-private
Here is the configuration
vyos@R1:~$ show configuration commands | strip-private
set interfaces ethernet eth0 address 'xxx.xxx.10.100/24'
set interfaces ethernet eth0 hw-id 'xx:xx:xx:xx:xx:9e'
set interfaces ethernet eth1 address 'xxx.xxx.20.100/24'
set interfaces ethernet eth1 hw-id 'xx:xx:xx:xx:xx:a8'
set interfaces ethernet eth2 address 'xxx.xxx.20.100/24'
set interfaces ethernet eth2 hw-id 'xx:xx:xx:xx:xx:b2'
set interfaces loopback lo
set interfaces vti vti1 address 'xxx.xxx.1.1/30'
set interfaces vti vti2 address 'xxx.xxx.2.1/30'
set load-balancing wan interface-health eth0 failure-count '3'
set load-balancing wan interface-health eth0 nexthop 'xxx.xxx.10.200'
set load-balancing wan interface-health eth0 success-count '2'
set load-balancing wan interface-health eth1 failure-count '3'
set load-balancing wan interface-health eth1 nexthop 'xxx.xxx.20.200'
set load-balancing wan interface-health eth1 success-count '2'
set load-balancing wan rule 10 inbound-interface 'eth2'
set load-balancing wan rule 10 interface eth0 weight '1'
set load-balancing wan rule 10 interface eth1 weight '1'
set load-balancing wan rule 10 protocol 'all'
set protocols static route xxx.xxx.0.0/0 next-hop xxx.xxx.10.200 interface 'eth0'
set protocols static route xxx.xxx.0.0/0 next-hop xxx.xxx.20.200 distance '5'
set protocols static route xxx.xxx.0.0/0 next-hop xxx.xxx.20.200 interface 'eth1'
set protocols static route xxx.xxx.40.100/32
set service ssh
set system host-name xxxxxx
set system ntp server xxxxx.tld
set system time-zone 'Asia/Kolkata'
set vpn ipsec esp-group TESTESP compression 'disable'
set vpn ipsec esp-group TESTESP lifetime '28800'
set vpn ipsec esp-group TESTESP mode 'tunnel'
set vpn ipsec esp-group TESTESP pfs 'dh-group5'
set vpn ipsec esp-group TESTESP proposal 10 encryption 'aes256'
set vpn ipsec esp-group TESTESP proposal 10 hash 'sha256'
set vpn ipsec ike-group TESTIKE dead-peer-detection action 'restart'
set vpn ipsec ike-group TESTIKE dead-peer-detection interval '5'
set vpn ipsec ike-group TESTIKE dead-peer-detection timeout '20'
set vpn ipsec ike-group TESTIKE ikev2-reauth 'no'
set vpn ipsec ike-group TESTIKE key-exchange 'ikev2'
set vpn ipsec ike-group TESTIKE lifetime '28800'
set vpn ipsec ike-group TESTIKE proposal 10 dh-group '5'
set vpn ipsec ike-group TESTIKE proposal 10 encryption 'aes256'
set vpn ipsec ike-group TESTIKE proposal 10 hash 'sha256'
set vpn ipsec interface 'eth0'
set vpn ipsec interface 'eth1'
set vpn ipsec site-to-site peer xxxxx.tld authentication id 'xxx.xxx.10.100'
set vpn ipsec site-to-site peer xxxxx.tld authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer xxxxx.tld authentication pre-shared-secret xxxxxx
set vpn ipsec site-to-site peer xxxxx.tld authentication remote-id 'xxx.xxx.30.100'
set vpn ipsec site-to-site peer xxxxx.tld connection-type 'initiate'
set vpn ipsec site-to-site peer xxxxx.tld description 'R!-R#'
set vpn ipsec site-to-site peer xxxxx.tld ike-group 'TESTIKE'
set vpn ipsec site-to-site peer xxxxx.tld ikev2-reauth 'inherit'
set vpn ipsec site-to-site peer xxxxx.tld local-address 'xxx.xxx.10.100'
set vpn ipsec site-to-site peer xxxxx.tld vti bind 'vti1'
set vpn ipsec site-to-site peer xxxxx.tld vti esp-group 'TESTESP'
