Ulrik
April 4, 2021, 7:04pm
1
Hi All,
I am trying to configure a Wireguard interface as a “client” to a server that has provided a pre generated keypair.
I have set the private-key setting on the interface with the encoded key provided from the server.
set interfaces wireguard wg0 private-key gybbeligoggybeligog=
But when i commit the config i get the error:
Wireguard private-key not found! Execute: “run generate wireguard [default-keypair|named-keypairs]”
Is it really not possible to configure wireguard with keys that are not generated by the generate wireguard named-keypairs command ?
You can replace your named private key.
vyos@r4-roll# run generate wireguard named-keypairs foo
vyos@r4-roll#
vyos@r4-roll# ls /config/auth/wireguard/foo/
private.key public.key
vyos@r4-roll# set interfaces wireguard wg0 private-key
Possible completions:
<text> Private key to use on that interface
foo
Ulrik
April 4, 2021, 8:12pm
3
That worked. Thanks for for the crazy quick reply.
system
Closed
April 6, 2021, 8:13pm
4
