Hi all, I’m trying to set up a connection to Mullvad using 1.4-rolling-202111200317, and the connection is up and handshaking, but I can’t send any data over it. Regardless of routing, should I still just be able to ping over that interface (ping -I wg1 1.1.1.1) and get a response?
As you can see in my configuration below, I’m trying to route a specific network group via the VPN, but the route doesn’t appear in the routing table. I’m new to zone-policy and PBR though, so I’m not sure if it’s meant to. But regardless, shouldn’t I still be able to ping or do some other kind of test to get data over that interface, regardless of routing?
The reason I have both eth1 and pppoe0 as my WAN interface in the config is that I’m prototyping it on my existing network. Occasionally I have been testing functionality direct to the internet, when I switch to the pppoe0 connection to my ISP (hardening some of the rules as I do). It’s currently disabled. I haven’t had any other problems with this config, though, whether using pppoe0 or eth1 directly as my WAN interface. I have a wireguard roadwarrior working well, as is everything else. I just haven’t been able to traffic data over my mullvad connection.
I’ve tried having the firewall off completely, and I’ve tried other VPN providers. They all handshake but I’m unable to ping via it. Don’t worry too much about the mtu and mss settings in the below, they’re just something I’ve been playing with for another reason, but I’ve removed all of those and found the same behaviour. I think there is something very basic about routing that I’ve misunderstood.
Any guidance appreciated, if there are any log outputs that will help please let me know what commands will provide them. Many thanks.
Some info:
$ sudo wg
interface: wg1
public key: xxxxxx
private key: (hidden)
listening port: 39407
peer: xxxxxx
endpoint: xx.xx.xx.xx:51820
allowed ips: 0.0.0.0/0
latest handshake: 1 minute, 13 seconds ago
transfer: 9.61 KiB received, 288.95 KiB sent
persistent keepalive: every 10 seconds
# ping -I wg1 1.1.1.1
PING 1.1.1.1 (1.1.1.1) from 10.0.40.1 wg1: 56(84) bytes of data.
^C
--- 1.1.1.1 ping statistics ---
17 packets transmitted, 0 received, 100% packet loss, time 16400ms
$ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.1.1 0.0.0.0 UG 20 0 0 eth1
10.0.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth2
10.0.30.0 0.0.0.0 255.255.255.0 U 0 0 0 wg2
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
$ ip route
default nhid 11 via 192.168.1.1 dev eth1 proto static metric 20
10.0.0.0/24 dev eth2 proto kernel scope link src 10.0.0.1
10.0.30.0/24 dev wg2 proto kernel scope link src 10.0.30.1
192.168.1.0/24 dev eth1 proto kernel scope link src 192.168.1.11
My config:
container {
name adguardhome {
allow-host-networks
image adguard/adguardhome
volume conf {
destination /opt/adguardhome/conf
source /config/mine/adguardhome/conf
volume work {
destination /opt/adguardhome/work
source /config/mine/adguardhome/work
name pixelserv-tls {
allow-host-networks
image imthai/pixelserv-tls
volume conf {
destination /var/cache/pixelserv
source /config/mine/pixelserv-tls
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
group {
network-group PRIVATE {
description "private ranges"
network xxx.xxx.0.0/16
network xxx.xxx.0.0/12
network xxx.xxx.0.0/8
network xxx.xxx.0.0/10
network-group VIAVPN {
network xxx.xxx.0.128/27
network xxx.xxx.30.0/24
ipv6-src-route disable
ip-src-route disable
log-martians enable
name LAN-LOCAL {
default-action accept
name LAN-VPN {
name LAN-WAN {
name LOCAL-LAN {
name LOCAL-VPN {
name LOCAL-WAN {
name VPN-LAN {
default-action drop
enable-default-log
rule 5 {
action accept
state {
established enable
related enable
rule 6 {
action drop
log enable
state {
invalid enable
rule 10 {
action drop
description "block private networks"
log enable
group {
name VPN-LOCAL {
enable-default-log
rule 5 {
action accept
state {
established enable
related enable
rule 6 {
action drop
log enable
state {
invalid enable
rule 10 {
action drop
log enable
group {
rule 20 {
action accept
log enable
protocol icmp
state {
new enable
name WAN-LAN {
default-action drop
enable-default-log
rule 5 {
action accept
state {
established enable
related enable
rule 6 {
action drop
log enable
state {
invalid enable
rule 10 {
action drop
disable
log enable
group {
name WAN-LOCAL {
enable-default-log
rule 5 {
action accept
state {
established enable
related enable
rule 6 {
action drop
log enable
state {
invalid enable
rule 10 {
action drop
disable
log enable
group {
rule 20 {
action accept
description "Allow ICMP"
log enable
protocol icmp
state {
new enable
rule 30 {
action accept
description "Allow SSH"
destination {
port 22
log enable
protocol tcp
state {
new enable
rule 40 {
action accept
description "Allow Wireguard RoadWarrior"
destination {
port 51031
log enable
protocol udp
send-redirects enable
source-validation disable
syn-cookies enable
address dhcp
description WAN
hw-id xx:xx:xx:xx:xx:0d
ip {
adjust-mss 1420
ipv6 {
address {
no-default-link-local
mtu 1492
ethernet eth2 {
address xxx.xxx.0.1/24
description LAN
hw-id xx:xx:xx:xx:xx:10
ip {
adjust-mss 1420
ipv6 {
address {
mtu 1492
policy {
route VPN
loopback lo {
pppoe pppoe0 {
authentication {
password xxxxxx
user xxxxxx
default-route auto
disable
ip {
adjust-mss 1420
mtu 1492
no-peer-dns
source-interface eth1
wireguard wg1 {
address xxx.xxx.40.1/32
description MullvadVPN
ip {
adjust-mss 1372
ipv6 {
address {
mtu 1412
peer au3 {
address xxx.xxx.88.2
allowed-ips xxx.xxx.0.0/0
persistent-keepalive 10
port 51820
public-key xxxxxx
private-key xxxxxx
wireguard wg2 {
address xxx.xxx.30.1/24
description RoadWarrior
ip {
adjust-mss 1372
ipv6 {
address {
mtu 1412
peer phone {
allowed-ips xxx.xxx.30.2/32
persistent-keepalive 15
public-key xxxxxx
port 51031
private-key xxxxxx
wireless wlan0 {
disable
hw-id xx:xx:xx:xx:xx:c4
ipv6 {
address {
physical-device phy0
nat {
rule 100 {
outbound-interface pppoe0
translation {
address masquerade
rule 200 {
outbound-interface eth1
translation {
address masquerade
rule 300 {
outbound-interface wg1
translation {
address masquerade
policy {
route VPN {
rule 1 {
description "Local destinations for all traffic"
destination {
group {
set {
table main
rule 100 {
description "Internet destinations for viavpn clients"
destination {
address xxx.xxx.0.0/0
set {
table 100
group {
protocols {
static {
table 100 {
route xxx.xxx.0.0/0 {
blackhole {
distance 255
interface wg1 {
service {
ssh {
port 22
system {
config-management {
commit-revisions 100
conntrack {
modules {
ftp
h323
nfs
pptp
sip
sqlnet
tftp
console {
device ttyS0 {
speed 115200
domain-name xxxxxx
host-name xxxxxx
ipv6 {
disable
disable-forwarding
login {
banner {
post-login ""
pre-login ""
user xxxxxx {
authentication {
encrypted-password xxxxxx
public-keys xxxx@xxx.xxx {
key xxxxxx
type ssh-rsa
home-directory /config/mine/xxxxxx
user xxxxxx {
authentication {
name-server xxx.xxx.0.1
ntp {
server xxxxx.tld {
sysctl {
parameter net.ipv6.conf.lo.disable_ipv6 {
value 1
syslog {
global {
facility all {
level info
facility protocols {
level debug
time-zone Australia/Hobart
zone-policy {
zone LAN {
default-action drop
from LOCAL {
firewall {
name LOCAL-LAN
from VPN {
firewall {
name VPN-LAN
from WAN {
firewall {
name WAN-LAN
interface eth2
interface wg2
zone LOCAL {
default-action drop
from LAN {
firewall {
name LAN-LOCAL
from VPN {
firewall {
name VPN-LOCAL
from WAN {
firewall {
name WAN-LOCAL
local-zone
zone VPN {
default-action drop
from LAN {
firewall {
name LAN-VPN
from LOCAL {
firewall {
name LOCAL-VPN
interface wg1
zone WAN {
default-action drop
from LAN {
firewall {
name LAN-WAN
from LOCAL {
firewall {
name LOCAL-WAN
interface eth1
interface pppoe0
