Wireguard forgets tunnel endpoint
Hi, I have configured a wireguard tunnel to some IPv6 endpoint:
@r1# show interfaces wireguard wg212895 | strip-private
 address xxxx:xxxx:f00:b8::2/64
 peer peer {
     address xxxx:xxxx:4::1
     allowed-ips ::/0
     persistent-keepalive 30
     port 44393
     public-key lgxXREeixNDJ0zdTTSvTgKI1hZuTAxyGvM0NVAad5TI=
 private-key xxxxxx
Suddenly my tunnel was gone and taking a look running sudo wg showed that wireguard was trying to contact endpoint: [xxxx:xxxx:a::4]:44393 which is not configured anywhere.
Running
r1:~$ reset wireguard interface wg212895
Resetting wg212895 peer lgxXREeixNDJ0zdTTSvTgKI1hZuTAxyGvM0NVAad5TI= from [xxxx:xxxx:a::4]:44393 endpoint to xxxx:xxxx:4::1:44393 ... done
solved the issue.
I’ve now had this issue multiple times on different VyOS installs. I don’t find a command to show wireguard logs, how can I investigate further?
set system option kernel debug wireguard
Thanky you, I have now set that and will report with logs when it happens again.
Can you also check if this service is running or not: systemctl status vyos-domain-resolver
○ vyos-domain-resolver.service - VyOS firewall domain resolver
     Loaded: loaded (/lib/systemd/system/vyos-domain-resolver.service; disabled; preset: enabled)
     Active: inactive (dead)
Mar 07 13:12:29 r1 systemd[1]: vyos-domain-resolver.service - VyOS firewall domain resolver was skipped because of an unmet condition check (ConditionPathExistsGlob=/run/use-vyos-domain-resolver*).
Mar 07 13:12:31 r1 systemd[1]: vyos-domain-resolver.service - VyOS firewall domain resolver was skipped because of an unmet condition check (ConditionPathExistsGlob=/run/use-vyos-domain-resolver*).
Mar 07 13:12:32 r1 systemd[1]: vyos-domain-resolver.service - VyOS firewall domain resolver was skipped because of an unmet condition check (ConditionPathExistsGlob=/run/use-vyos-domain-resolver*).
Mar 07 13:12:33 r1 systemd[1]: vyos-domain-resolver.service - VyOS firewall domain resolver was skipped because of an unmet condition check (ConditionPathExistsGlob=/run/use-vyos-domain-resolver*).
Mar 14 21:21:29 r1 systemd[1]: vyos-domain-resolver.service - VyOS firewall domain resolver was skipped because of an unmet condition check (ConditionPathExistsGlob=/run/use-vyos-domain-resolver*).
Mar 14 21:23:59 r1 systemd[1]: vyos-domain-resolver.service - VyOS firewall domain resolver was skipped because of an unmet condition check (ConditionPathExistsGlob=/run/use-vyos-domain-resolver*).
It’s not running, what does this service do?
It‘s main purpose is to resolve FQDNs in the background for domain name firewall rules or dynamic WireGuard endpoints.
Do you have more then one WireGuard peer or only this one? How long does it take to disappear?
Also whats your VyOS version?
I have multiple Wireguard Tunnels. So far it always happened only to wg212895 on every install.
 wireguard wg02 {
     peer peer {
         address xxx.xxx.118.205
         allowed-ips ::/0
         port 50001
         public-key m83+9yvI33jplsXaF4GE/BH4LbwlRXQQTrTnRb8QaUE=
     port 50002
     private-key xxxxxx
 wireguard wg209533 {
     address xxxx:xxxx:a005::2f2/126
     peer peer {
         address xxx.xxx.85.10
         allowed-ips ::/0
         persistent-keepalive 60
         port 51900
         public-key W0pI832mL5u7JzJjiE68dyS95mIGBDqGgSxSZromEGY=
     private-key xxxxxx
 wireguard wg212895 {
     peer peer {
         allowed-ips ::/0
         port 44393
     private-key xxxxxx
 wireguard wg213408 {
     address xxxx:xxxx:b7a::c1:2/127
     peer peer {
         address xxxx:xxxx:1c1b:f904::1
         allowed-ips ::/0
         port 60002
         public-key i6J7Cu3nUFQrpJVkchrY270hMExjO7kTjyIvVbXayUY=
     port 60001
     private-key xxxxxx
 wireguard wg213416 {
     address xxxx:xxxx:b7a::c1:0/127
     peer peer {
         address xxxx:xxxx:221:3401::100
         allowed-ips ::/0
         port 60000
         public-key tBisp7mr50xOpdaIO9PoYoYpU+HaRaWF2b8o0+BrmCs=
     port 60000
     private-key xxxxxx
Last time it tooke 9 days to act up. I do not recall how long it took before, but it should be similar.
Version:
@r1:~$ show version
Version:          VyOS 1.5-rolling-202503030030
Release train:    current
Release flavor:   generic
Built by:         [email protected]
Built on:         Mon 03 Mar 2025 00:30 UTC
Build UUID:       eaf46be4-549d-4701-b07e-e935b2b2ad2d
Build commit ID:  c54fba1fd7422e
Architecture:     x86_64
System type:      KVM guest
Secure Boot:      disabled
Hardware vendor:  Hetzner
Hardware model:   vServer
Hardware S/N:     60922795
Hardware UUID:    8978fc69-4826-4821-b8b8-e6cde87c408b
