Hello, I’ve been testing configurations for more than 6 hours and I can’t find the right one.
I want to configure Wireguard site to site, what is the correct configuration for vyos 1.3.6?
Wireguard doesn’t work, it doesn’t do anything, I have open ports, tried with tcpdump but it doesn’t do anything. I don’t see any log, I don’t see any debug, it is a good tool but poorly implemented.
As far as I know. vyos 1.3.6 has no issue with running wireguard. I upgrade lots of vyos 1.3.x to the latest vyos 1.3.6
Follow the official document please WireGuard — VyOS 1.3.x (equuleus) documentation
Or maybe you can share your network topology and configuration with the command
Wireguard in Vyos works very well. This message has gone over a Vyos configured Wireguard instance.
If you can provide your configuration we will be able to provide some better support - “It doesn’t work it doesn’t do anything” isn’t something we can work with I’m afraid.
A very, very common mistake (one I’ve made myself) is to put “allowed-ips 0.0.0.0/0” on multiple peers. That doesn’t work - here’s why.
