I’m trying to set up a wireguard tunnel with a tunnel terminating in one VRF but tunnel entry points in another. Is this a supported configuration in 1.3?
Version: VyOS 1.3-rolling-202104120642
Release Train: equuleus
Built by: autobuild@vyos.net
Built on: Tue 13 Apr 2021 03:42 UTC
Build UUID: 1058c7ab-3226-41b3-a5b1-ba014c8a413d
Build Commit ID: e0a176ba819b4a
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: PC Engines
Hardware model: apu2
Hardware S/N: 1119436
Hardware UUID: Unknown
I was using a similar setup in Junos/SRX with GRE tunnels and trying to achieve the same result with wireguard in VyOS.
here is an example of the config:
description WAN
duplex auto
hw-id XX:XX:XX:XX:XX:31
speed auto
vif 35 {
description PROVIDER1-DSL
pppoe pppoe0 {
authentication {
password xxxxxx
user xxxxxx
default-route none
description PROVIDER1-PPPOE
no-peer-dns
source-interface eth1.35
vrf ISP-PROVIDER1
wireguard wg23 {
address fe80::23/64
address xxxx:xxxx:6000:fff9::a/64
address xxx.xxx.128.120/31
description tun-r2-r3
ip {
ospf {
dead-interval 40
hello-interval 10
network point-to-point
priority 1
retransmit-interval 5
transmit-delay 1
mtu 1412
peer r3 {
address xxx.xxx.221.227
allowed-ips ::/0
allowed-ips xxx.xxx.0.0/0
port 51820
pubkey 9hM1lGIzCvsqM7s+9vqLvymljrNAqt3xKsJNo+g0X3w=
port 51820
private-key default
policy {
route-map OSPF-DIST {
rule 10 {
action permit
match {
interface eth0
rule 20 {
action permit
match {
interface wg23
protocols {
bfd {
peer xxxxx.tld {
peer xxxx:xxxx:6000:fff9::b {
ospf {
area 0 {
network xxx.xxx.128.0/24
log-adjacency-changes {
parameters {
abr-type cisco
rfc1583-compatibility
router-id xxx.xxx.128.130
redistribute {
connected {
metric-type 2
route-map OSPF-DIST
ospfv3 {
area 0 {
interface eth0
interface wg23
parameters {
redistribute {
connected
static {
route xxx.xxx.128.0/24 {
blackhole {
route6 xxxx:xxxx:6000::/48 {
blackhole {
vrf ISP-PROVIDER1 {
static {
interface-route xxx.xxx.0.0/0 {
next-hop-interface pppoe0 {
interface-route xxx.xxx.221.224/29 {
interface-route6 ::/0 {
interface-route6 xxxx:xxxx:1001:2a::/64 {
route6 xxxx:xxxx:f00f:aa00::/56 {
blackhole {
vrf {
name ISP-PROVIDER1 {
table 200
name mgmt {
table 100
The goal is to isolate/hide static routes for tunnel endpoints from the main routing table. Essentially, the pppoe0 interface is in one VRF but wg23 is in another.
I was unable to make it work so far.
Thanks
