System: VyOS 1.4, private build from the 1.4 Sagitta branch, pulled February 5, 2024.
I’ve verified the same issue exists in the latest 1.5 rolling
image as well; tested on vyos-1.5-rolling-202408160021-amd64
– identical behavior
In brief:
I’m trying to write a custom migration script that sets the system monitoring zabbix-agent server-active
parameter, as well as a server-active port
when I install a new image, however, the resulting config formatting breaks the config parser.
In detail:
Goal: set the zabbix server-active
hostname and port with a migration script.
What does work: CLI
If I use the CLI to set the parameter, the syntax goes like this:
config
set service monitoring zabbix-agent server zabbix.example.com
set service monitoring zabbix-agent port 10050
set service monitoring zabbix-agent server-active zabbix.example.com port 10051
commit
save
The resulting config looks like this:
monitoring {
zabbix-agent {
server-active zabbix.example.com {
port 10051
port 10050
All good.
Where it breaks: migration script
However, if I try to set the server-active
details in a custom migration script, like so:
config.set(['service', 'monitoring', 'zabbix-agent', 'server-active', 'zabbix.example.com', 'port'], value='10051')
THEN the resulting config looks like this:
monitoring {
zabbix-agent {
server-active {
port "10051"
port "10050"
server "zabbix.example.com"
which breaks the system at boot-time when the new image runs the migration: the config file parser chokes on the unexpected .
in the zabbix.example.com
“hostname” under server-active
at boot time with this error (running with vyos-config-debug
enabled at boot):
vyos@vyosrouter:~$ cat /tmp/boot-config-trace
File "/usr/libexec/vyos/vyos-boot-config-loader.py", line 141, in <module>
load_out = session.load_config(file_name)
File "/usr/lib/python3/dist-packages/vyos/configsession.py", line 201, in load_config
out = self.__run_command(LOAD_CONFIG + [file_path])
File "/usr/lib/python3/dist-packages/vyos/configsession.py", line 144, in __run_command
raise ConfigSessionError(output)
vyos.configsession.ConfigSessionError: Invalid config file (syntax error): error at line 1514, text [.]
Failed to parse specified config file
Can one of the developers weigh in on this? Or maybe someone sees what I’m doing wrong?
Proposed solution:
In my opinion, the relevant bit of config syntax should look like this instead:
set service monitoring zabbix-agent server-active host zabbix.example.com
set service monitoring zabbix-agent server-active port 10051
which would result in a config something like this:
monitoring {
zabbix-agent {
server-active {
host "zabbix.example.com"
port "10051"
port "10050"
I’m happy to open a ticket on Phabricator if that’s the preferred place to discuss further.
