Zone based firewall at enterprise edge with multiple LAN interfaces
We have an enterprise edge router with 1x WAN interface and 3x LAN interfaces to different core routers, and a local loopback interface.
I plan to define 3 zones
set firewall zone WAN interface eth1
set firewall zone LAN interface 'eth2,eth3,eth4'
set firewall zone LOCAL local-zone
Q1. VyOS doc states “Traffic cannot flow between zone member interface.” Does it mean traffic cannot be routed between eth2, eth3, and eth4?
Q2. Given I configured a ruleset allowing BGP peering to WAN port. For applying rule-set to zone, will it be
set firewall zone WAN from WAN firewall name ALLOW-BGP-PEERING
or
set firewall zone LOCAL from WAN firewall name ALLOW-BGP-PEERING
Thanks!
It can flow between interfaces within a zone, you may need to enable
set firewall zone WAN intra-zone-filtering action 'accept'
set firewall zone LAN intra-zone-filtering action 'accept'
Stateful firewall configuration
# Global state policy
set firewall global-options state-policy established action 'accept'
set firewall global-options state-policy invalid action 'drop'
set firewall global-options state-policy related action 'accept'
# if you are doing bridging/containers while above is set
set firewall global-options apply-to-bridged-traffic accept-invalid <type>
# Alternatively, have statements in each policy to allow related/established, drop invalid
set firewall ipv4 name WAN-to-LAN rule 10 action accept
set firewall ipv4 name WAN-to-LAN rule 10 description "Allow Related/Established Traffic"
set firewall ipv4 name WAN-to-LAN rule 10 state established
set firewall ipv4 name WAN-to-LAN rule 10 state related
set firewall ipv4 name WAN-to-LAN rule 20 action drop
set firewall ipv4 name WAN-to-LAN rule 20 description "Drop Invalid"
set firewall ipv4 name WAN-to-LAN rule 20 state invalid
To apply a policy, it’s in the mindset of “from Zone to Zone”, eg
set firewall ipv4 name ALLOW-ALL default-action 'accept'
set firewall ipv4 name DENY-ALL default-action 'drop'
set firewall zone WAN from LAN firewall ipv6-name 'ALLOW-ALL'
set firewall zone WAN from LAN firewall name 'ALLOW-ALL'
set firewall zone WAN from LOCAL firewall ipv6-name 'ALLOW-ALL'
set firewall zone WAN from LOCAL firewall name 'ALLOW-ALL'
set firewall zone WAN member interface 'eth1'
set firewall zone LAN from LOCAL firewall ipv6-name 'ALLOW-ALL'
set firewall zone LAN from LOCAL firewall name 'ALLOW-ALL'
set firewall zone LAN from WAN firewall ipv6-name 'DENY-ALL'
set firewall zone LAN from WAN firewall name 'DENY-ALL'
set firewall zone LAN member interface 'eth2'
set firewall zone LAN member interface 'eth3'
set firewall zone LAN member interface 'eth4'
set firewall zone LOCAL from LAN firewall ipv6-name 'ALLOW-ALL'
set firewall zone LOCAL from LAN firewall name 'ALLOW-ALL'
set firewall zone LOCAL from WAN firewall ipv6-name 'WAN-to-LOCAL'
set firewall zone LOCAL from WAN firewall name 'WAN-to-LOCAL'
If you’re doing zone based firewall, you should structure your policies to be “From Zone to Zone”, eg WAN-to-LAN, LOCAL-to-WAN, etc. You can only point at a single policy on your zone for traffic from another zone, so a rule like ALLOW-BGP-PEERING is too specific for a policy that is meant to be for ALL traffic from WAN towards LOCAL.
You could have a policy named WAN-to-LOCAL and then in that you would have a statement that allows BGP peering, eg
# Use a network group or address group (network group is more flexible)
set firewall group network-group BGP-PEERS network 10.10.10.10/32
set firewall group address-group BGP-PEERS address 10.10.10.10
set firewall ipv4 name WAN-to-LOCAL default-action 'drop'
set firewall ipv4 name WAN-to-LOCAL rule 10 action 'accept'
set firewall ipv4 name WAN-to-LOCAL rule 10 description 'Allow ICMP'
set firewall ipv4 name WAN-to-LOCAL rule 10 protocol 'icmp'
set firewall ipv4 name WAN-to-LOCAL rule 20 action 'accept'
set firewall ipv4 name WAN-to-LOCAL rule 20 description 'Allow BGP from Peers'
set firewall ipv4 name WAN-to-LOCAL rule 20 protocol 'tcp'
set firewall ipv4 name WAN-to-LOCAL rule 20 destination port 'bgp'
set firewall ipv4 name WAN-to-LOCAL rule 20 source group network-group BGP-PEERS
Thank you very much for the clarification!
