Two strange things are happening.
First off, this config fails to redistribute my static route (default gateway):
static {
route 0.0.0.0/0 {
next-hop xx.xx.xx.1 {
ospf {
area 0 {
network 10.253.253.0/24
log-adjacency-changes {
parameters {
abr-type cisco
router-id 10.255.255.1
redistribute {
connected {
metric-type 2
static {
metric-type 2
Though that might be okay. I’m not sure if it’s supposed to redistribute 0.0.0.0/0. The bigger problem here is this config, that uses the “Default information” to redistribute the default route.
ospf {
area 0 {
default-information {
originate {
always
metric 10
metric-type 2
parameters {
abr-type cisco
redistribute {
connected {
metric-type 2
static {
metric-type 2
This config works as expected. The default route gets distributed. The problem is after 10 or 15 minutes, it stops sending the default route. The only way to get it back is to force the ospfd daemon to restart (or reboot the box).
It’s worth mentioning it’s ONLY the default that’s not getting redistributed. The connected seem to stay connected.
For now I’ve rolled back to RC4 to see if the problem exists there.
