Best way to organise firewall rules
As the avid reader will know, I’m working on automated migration of Sophos UTM firewalls to VyOS.
Sophos UTM is object based, so you have a firewall rule that says “traffic from these objects to these objects using these protocols and these ports is allowed”.
So say I have a rule that defines:
source objects: NETWORKGROUP1, NETWORKGROUP2, NETWORKADDRESS1
destination objects: NETWORKGROUP3,NETWORKADDRESS1,NETWORKADDRESS2
service objects: 80-tcp, 443-tcp, 22-tcp, 143-udp, 445-tcp
As I understand, a VyOS firewall (I assume the underlying nftables) can only have once source, one destination, one protocol and one port or port-range per rule.
Does this mean I have to do something like
set firewall ipv4 forward filter rule 1 description ‘TEST’
set firewall ipv4 forward filter rule 1 action jump
set firewall ipv4 forward filter rule 1 jump-target FWR000001
set firewall ipv4 name FWR000001 default-action return
set firewall ipv4 name FWR000001 rule 1 source group network-group NETWORKGROUP1
set firewall ipv4 name FWR000001 rule 1 destination group network-group NETWORKGROUP3
set firewall ipv4 name FWR000001 rule 1 protocol tcp
set firewall ipv4 name FWR000001 rule 1 destination port 80
set firewall ipv4 name FWR000001 rule 1 action accept
And so on, for every possible combination of source, destination and service (so 3 x 3 x 5 = 45 seperate rules for FWR000001) ? Times 2 if all source and destination objects define both IPv4 and IPv6 addresses?
Or can this be done a lot smarter and compacter than this?
You can do this with VyOS:
         network-group SOURCEGROUPS {
             description "All My Source Groups"
             include NETWORKGROUP1
             include NETWORKGROUP2
             include NETWORKGROUP3
         network-group DESTGROUPS {
             description "All My Destination Groups"
Then you can do
name test {
    rule 10 {
        action accept
        destination {
            group {
                address-group DESTGROUPS
            port 80,443,22,143,445
            group {
                address-group SOURCEGROUPS
etc etc.
Hope this helps.
Thanks,
I’ve found this yesterday in the source, the docs are severely lacking in some area’s.
I’ve already started coding for this consolidation. I’ve consolidated protocol and ports, I now have to do the same for addresses and network groups.
And then I should have it reduced to a still very large number of maximum 32 rules:
  • 1 x UDP + all ports
  • 1 x TCP + all ports
  • 4 x IPv4 (address groups + network groups, source and destination)
  • 4 x IPv6 (address groups + network groups, source and destination)
I have a feeling this can still be improved?
