Build ISO equuleus failed squashfs-tools
Hi guys!
I was trying to build VyOS 1.3 Equuleus. I’m able to build current VyOS 1.4 with success but VyOS 1.3 give me an error when I want to build it.
This is the error. Does anyone know how to fix this?
Calculating upgrade...
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Reading package lists...
Building dependency tree...
[2021-11-18 03:06:23] lb binary_rootfs
P: Begin building root filesystem image...
Some packages could not be installed. This may mean that you have
 squashfs-tools : Depends: libzstd1 (>= 1.4.0) but 1.3.8+dfsg-3+deb10u2 is to be installed
P: Saving caches...
make: *** [Makefile:32: iso] Error 1
vyos_bld@1a09316fdcf8:/vyos/vyos-build$
It says that you need to update the pkg
sudo apt update
sudo apt upgrade libzstd1
Even with sudo apt upgrade libzstd1
It installed 1.3.8 version. Even If I put the 1.4.8 deb package in the packages folder or installing the deb directly to the container, the issue is the same.
I have same issue here
You will find the solution here
