I’m setting up a new vyos install to handle some lab machines that will need to talk to an upstream tftp server for pxeboot handling.
vyos version: VyOS 1.4-rolling-202306200647
bare metal install
I’ve confirmed nf_conntrack_tftp and nf_nat_tftp are both loaded:
lsmod | grep conntrack
nf_conntrack_tftp 20480 1 nf_nat_tftp
nf_conntrack_sip 45056 1 nf_nat_sip
nf_conntrack_pptp 24576 1 nf_nat_pptp
nf_conntrack_h323 77824 1 nf_nat_h323
nf_conntrack_ftp 24576 1 nf_nat_ftp
nf_conntrack 180224 14 nf_nat,nf_conntrack_tftp,nfnetlink_cthelper,nft_ct,nf_nat_ftp,nf_conntrack_pptp,nf_nat_tftp,nf_conntrack_sip,nf_conntrack_h323,nf_nat_pptp,nf_conntrack_ftp,nft_masq,nf_nat_h323,nf_nat_sip
nf_defrag_ipv6 24576 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
lsmod | grep tftp
nf_nat_tftp 16384 0
nf_nat 57344 7 nf_nat_ftp,nf_nat_tftp,nf_nat_pptp,nft_masq,nf_nat_h323,nft_chain_nat,nf_nat_sip
I’ve configured both subnets to be masquerade nat’d:
show nat
rule 10 {
log
outbound-interface eth0
address 172.17.32.0/20
translation {
address masquerade
rule 11 {
log
address 172.17.16.0/20
translation {
address masquerade
However even thou the nat seems to be working in other respects you end up with issues when udp services attempt to respond.
The nat entry gets created:
Id Original src Original dst Reply src Reply dst Protocol State Timeout Mark Zone
1178614433 172.17.16.15:5726 <tftp-server>:69 <tftp-server>:69 <router>:5726 udp 28 0
but the tcp dump shows that the router is responding that the router is failing to deliver the response to the port:
16:49:08.755080 IP <router-ip>.5726 > <tftp-serverip>.tftp: 53 RRQ "pxelinux.0" octet tsize 0 blksize 1468 windowsize 4
16:49:08.755107 IP <router-ip>.5726 > <tftp-server-contiainer>.tftp: 53 RRQ "pxelinux.0" octet tsize 0 blksize 1468 windowsize 4
16:49:08.755113 IP <router-ip>.5726 > <tftp-server-contiainer>.tftp: 53 RRQ "pxelinux.0" octet tsize 0 blksize 1468 windowsize 4
16:49:08.758876 IP <tftp-server-contiainer>.43941 > <router-ip>.5726: UDP, length 27
16:49:08.758904 IP <tftp-serverip>.43941 > <router-ip>.5726: UDP, length 27
16:49:08.759125 IP <router-ip> > <tftp-serverip>.110: ICMP <router-ip> udp port 5726 unreachable, length 63
16:49:08.759136 IP <router-ip> > <tftp-server-contiainer>: ICMP <router-ip> udp port 5726 unreachable, length 63
16:49:08.759139 IP <router-ip> > <tftp-server-contiainer>: ICMP <router-ip> udp port 5726 unreachable, length 63
I’ve also tried replacing the nat with a port forward so when clients attempt to hit their gateway IP at port 69 it forwards to the appropriate server. this unfortunately has also failed.
This system is using zoned firewalls and outside-lan has a specific carveout to allow all traffic from the imaging server in, related and established are also enabled. I can provide sanitized firewall rules if that will help as well.
The tftp server being talked to is tftpd running in centos 9 stream to support a cobblerd instance.
side notes:
- clients behind both masquerade ports can’t make tftp connections
- traceroute fails from behind these ports as well
- ping works just fine
- tftp gets from the local router to the tftp server work
- tftp gets from devices behind the router to a tftp server on the router work
Any idea how to make this work?
