Help in Load-Balance Over VXLAN Tunnel
I Used the following Config to set up load-balance Over VXLAN Tunnel in WAN side Underlay. But I could not do it with the following settings. In each scenario, traffic passes through only one VXLAN Tunnel.
Can I set up load-balance over VXLAN Tunnel in Vyos?
I use VyOS 1.3.0-epa1 version for both routers I have in my scenario.
Release train: equuleus
System type: bare metal
Topology
configuration
Vyos1:
set interface ethernet eth0 address dhcp
set interface ethernet eth1 address 172.16.1.1/24
set interface ethernet eth3 address 172.16.2.1/24
set protocols ospf area 0 network 172.16.1.0/24
set protocols ospf area 0 network 172.16.2.0/24
set protocols ospf redistribute connected
vyos2:
set interface ethernet eth1 address 172.16.1.2/24
set interface ethernet eth3 address 172.16.2.2/24
vyos1: first vxlan Bridge.
set interfaces bridge br241 address ‘172.16.241.1/24’
set interfaces bridge br241 member interface ‘eth2’
set interfaces bridge br241 member interface ‘vxlan241’
set interfaces vxlan vxlan241 group ‘239.0.0.241’
set interfaces vxlan vxlan241 source-interface ‘eth1’
set interfaces vxlan vxlan241 mtu 1400
set interfaces vxlan vxlan241 port 4789
set interfaces vxlan vxlan241 vni ‘241’
vyos2: first vxlan Bridge.
vyos1: second vxlan Bridge.
set interfaces bridge br242 address ‘172.16.242.1/24’
set interfaces bridge br242 member interface ‘eth2’
set interfaces bridge br242 member interface ‘vxlan242’
set interfaces vxlan vxlan242 group ‘239.0.0.242’
set interfaces vxlan vxlan242 source-interface ‘eth3’
set interfaces vxlan vxlan242 mtu 1400
set interfaces vxlan vxlan242 port 4789
set interfaces vxlan vxlan242 vni ‘242’
vyos2: second vxlan Bridge.
set interfaces vxlan vxlan242 group '239.0.0.242
LoadBalancing
Vyos1:
set load-balancing wan interface-health vxlan241 nexthop 172.16.241.1 or 172.16.1.2
set load-balancing wan interface-health vxlan242 nexthop 172.16.242.1 or 172.16.2.2
set load-balancing wan rule 1 inbound-interface ‘eth2’
set load-balancing wan rule 1 interface vxlan241 weight 5
set load-balancing wan rule 1 interface vxlan242 weight 5
set load-balancing wan rule 1 per-packet-balancing
set load-balancing wan rule 1 protocoll-all
Vyos2:
set load-balancing wan interface-health vxlan241 nexthop 172.16.241.1 or 172.16.1.1
set load-balancing wan interface-health vxlan242 nexthop 172.16.242.1 or 172.16.2.1
I also used br241 and br242 as the interface-health, but the same results were observed.
Thank you very much in advance. I would appreciate any help.
It is incorrect to set the same interface “eth2” to different bridges.
Thank you for your attention.
Is it possible to use VXLAN tunnels for load balancing for the same traffic flow coming from Lan?
If possible, can you help me?
