Hi everybody,
with vxlan it is possible to use multiple remote addresses to connect 3 or more gateways to one cluster.
Vyos currently allows only one remote peer (or a multicast group or L3VPN).
Using bridges (and spanning tree) to bridge multiple vxlan interfaces aren’t a good workaround because load-balancing (something like this Help in Load-Balance Over VXLAN Tunnel) is not working.
With debian 11 an iproute2 I am using something like this in /etc/network/interfaces:
iface vxlan100
vxlan-id 42
vxlan_remoteip 10.1.2.1
vxlan_remoteip 10.2.2.1
mtu 1450
Proxmox also uses that for their SDN feature.
The “ip” command unfortunately don`t support adding interfaces with multiple remotes.
So you had to add the Interface without remote and then add them using “bridge” commands like this:
bridge fdb append to 00:00:00:00:00:00 dst 10.1.2.1 dev vxlan100
bridge fdb append to 00:00:00:00:00:00 dst 10.2.2.1 dev vxlan100
(its also possible to define the port for every remote)
Sources:
https://wiki.kleen.ch/vxlan
https://tecden.co.uk/linux/vxlan-and-namespaces-basic-concepts-creating-a-simple-isolated-router/
I wrote a little patch for vyos but I am not experienced enough in python and I am sure that could be done better.
First I had to add “multi:” to /opt/vyatta/share/vyatta-cfg/templates/interfaces/vxlan/node.tag/remote/node.def
Then I patched /usr/lib/python3/dist-packages/vyos/ifconfig/vxlan.py
vyos@testrouter# diff /tmp/vxlan.py "/usr/lib/python3/dist-packages/vyos/ifconfig/vxlan.py"
65c65
< 'remote' : 'remote',
> # 'remote' : 'remote',
84a85,89
> remote = dict_search('remote', self.config)
> for rem in remote:
> self.config["rem"] = rem
> cmd2 = 'bridge fdb append to 00:00:00:00:00:00 dst {rem} dev {ifname}'
> self._cmd(cmd2.format(**self.config))
Now this is possible:
set interfaces vxlan vxlan100 remote '10.1.2.1'
set interfaces vxlan vxlan100 remote '10.2.2.1'
set interfaces vxlan vxlan100 vni '10'
It’s working for some weeks. Also with “1.4-rolling-202112230317”.
Is it possible to get this feature into an official release?
Maybe also backported to Vyos 1.3?
