I am running BGP over GRE on my VyOS. I receive routes and full tables from upstream. This is for IPv6 only. I can’t ping any IPv6 hosts when BGP is running and connected to upstream.
When I run command ‘/usr/bin/traceroute 2606:4700:4700::1111’, the package will be dropped at the first hop. However, if I run it as ‘/usr/bin/traceroute --source=[my IPv6] 2606:4700:4700::1111’ and it will go through just find to the destination.
Any idea on why? And how do I change my settings to make outgoing IPv6 traffic flow normally. I have set IPv6 address within my BGP announcement to both eth0 (IPv4 WAN) and eth1 (LAN).
Here is my BGP configure
set protocols bgp [My AS Number] address-family ipv6-unicast network [My IPv6 /48 block]
set protocols bgp [My AS Number] neighbor 2a0c:9a40:100f:384::1 address-family ipv6-unicast prefix-list export ‘ExportTable’
set protocols bgp [My AS Number] neighbor 2a0c:9a40:100f:384::1 address-family ipv6-unicast route-map export ‘transit’
set protocols bgp [My AS Number] neighbor 2a0c:9a40:100f:384::1 address-family ipv6-unicast soft-reconfiguration inbound
set protocols bgp [My AS Number] neighbor 2a0c:9a40:100f:384::1 remote-as ‘34927’
set protocols bgp [My AS Number] parameters default no-ipv4-unicast
set protocols bgp [My AS Number] parameters router-id ‘my wan ipv4’
You are getting a route through tun0 and you want to send traffic through the WAN interface (not tun0)?
Can you give the output of the command: show interfaces
One thing very interesting. When I turn on IPv6 Router Advertisement, devices on the network could get IPv6 access. VyOS does know how to route traffic. It’s just the Router Itself doesn’t seem to know how to select proper IPv6 address for traffic.
vyos@r14# set policy route-map FOO rule 10 set ipv6-next-hop
Possible completions:
global Nexthop IPv6 global address
local Nexthop IPv6 local address
peer-address Use peer address (for BGP only)
prefer-global Prefer global address as the nexthop
