Persisting grub menu edits
I performed a fresh install of vyos-1.4-rolling-202112240317-amd64.iso on a new (to me) Wyse 3040.
I found on this system I need to delete the console= kernel options to actually see a console. It seems I can edit /etc/boot/grub.cfg manually to remove these options, but I assume the changes will be wiped (or at least not applied to future images) when I update. Is there a way to persist grub kernel command line changes across updates?
This seems to be the opposite problem in this post…
Thanks!
Hi would you be kind enough as i have same issue my bare metal box won’t boot without a monitor attached, i tried to edit grub file sudo /etc/default / grub
And uncommented GRUB_TERMINAL=console,but when try to save the file sudo update-grub it gives error failed to get canonical path of overlay ???
