Vamp
October 24, 2019, 4:54pm
1
Hello there,
My Config:
Host config (Proxmox)
4 x Intel® Core™ i3-5005U CPU @ 2.00GHz (1 Socket)
8 Gb RAM
VM config (VyOS)
2 core
512 Mb RAM
My net Speed: 1/1 Gbit PPPoE Optical
If i do a speed test, the max speed is about 600/600 Mbit and the CPU is maxed in VyOS VM. It mean that the hardware is not enough in this bandwith?
If i copy a file from the VM to a another machine (inside the LAN network), i able to use full bandwith (Gigabit) It need to update the hardware or some settings is wrong?
What the experience? similar hardware is possible to use a gigabit PPPoE connection?
Dmitry
October 24, 2019, 8:30pm
3
Hello @Vamp , can you share screenshot sudo top command and press 1 when speed test running?
I have idea. You can try configure RPS (Receive Packet Steering) manually for this case.
Note: Seems also 2.00GHz CPU not enough for this case.
Vamp
October 24, 2019, 8:44pm
4
Hello @Dmitry ,
Here the picture (some minute ago i set 4 core, it is the reason the 4 CPU)
Dmitry
October 24, 2019, 9:07pm
5
I hope you use network interface eth0
try set next
sudo su -l
echo "32768" > /proc/sys/net/core/rps_sock_flow_entries
echo "2" > /sys/class/net/eth0/queues/rx-0/rps_cpus
echo "4" > /sys/class/net/eth0/queues/rx-1/rps_cpus
echo "8" > /sys/class/net/eth0/queues/rx-2/rps_cpus
echo "1" > /sys/class/net/eth0/queues/rx-3/rps_cpus
echo "2048" > /sys/class/net/eth0/queues/rx-0/rps_flow_cnt
echo "2048" > /sys/class/net/eth0/queues/rx-1/rps_flow_cnt
echo "2048" > /sys/class/net/eth0/queues/rx-2/rps_flow_cnt
echo "2048" > /sys/class/net/eth0/queues/rx-3/rps_flow_cnt
exit
If you see any warnings, check please
ls /sys/class/net/eth0/queues/
Run speed test again and also provide please screenshot with sudo top command and output of commands
sudo cat /proc/softirqs
sudo ethtool -g eth0
Dmitry
October 25, 2019, 10:59pm
6
Hello @Vamp , do you have any results? As for me, this case very interesting.
Vamp
October 26, 2019, 6:41am
7
@Dmitry I can not test it, it a prodictive system but I try it at this weekend!
Vamp
October 28, 2019, 1:41pm
8
@Dmitry
I got warning this lines (missing file or directory)
I run this command:
root@vyos:~# ls /sys/class/net/eth0/queues/
rx-0 tx-0
And this command show this:
root@vyos:~# sudo cat /proc/softirqs
CPU0 CPU1 CPU2 CPU3
HI: 0 0 1 0
TIMER: 3707338 3040568 1230683 2733274
NET_TX: 347467 127506 93146 10768
NET_RX: 11912778 20839712 98250 100144
BLOCK: 0 0 0 0
IRQ_POLL: 0 0 0 0
TASKLET: 11 10 1 672
SCHED: 2619571 2327082 985307 1551294
HRTIMER: 0 0 0 0
RCU: 2596150 1948829 1148228 2121294
root@vyos:~# sudo ethtool -g eth0
Ring parameters for eth0:
Pre-set maximums:
RX: 256
RX Mini: 0
RX Jumbo: 0
TX: 256
Current hardware settings:
RX: 256
RX Mini: 0
RX Jumbo: 0
TX: 256
Dmitry
October 28, 2019, 7:44pm
9
Hello @Vamp . You can try use multiqueue for this machine NICs. I don’t have enough experience with proxmox, but I saw some information about it in proxmox docs.
Vamp
October 28, 2019, 9:55pm
10
@Dmitry I enable multiqueue with WAN network card (4 core), and do your changes. (without error) Here the result:
vyos@vyos:~$ sudo cat /proc/softirqs
CPU0 CPU1 CPU2 CPU3
HI: 1 0 0 0
TIMER: 107045 112344 173187 127780
NET_TX: 23 1018 10435 2758
NET_RX: 3539 121943 925750 5550
BLOCK: 0 0 0 0
IRQ_POLL: 0 0 0 0
TASKLET: 1 3 2 34
SCHED: 84858 76682 106472 81292
HRTIMER: 0 0 0 0
RCU: 122104 126720 160634 134672
vyos@vyos:~$ sudo ethtool -g eth0
Pre-set maximums:
RX: 256
RX Mini: 0
RX Jumbo: 0
TX: 256
RX: 256
RX Mini: 0
RX Jumbo: 0
TX: 256
Dmitry
October 28, 2019, 10:10pm
11
Seems IRQ utilizations looks better. What about speed?
Vamp
October 28, 2019, 10:28pm
12
Similar. But the cpu usage is better now.
Dmitry
October 29, 2019, 3:45pm
13
May be bottleneck is hypervisor? Is it possible use paththrough for NIC in this case?
Dmitry
January 15, 2020, 4:10pm
14
raab
February 4, 2020, 10:25am
15
Hi @Dmitry ,
I didn’t want to start a new thread, similar question. Running VyOS on a baremetal Supermicro SYS-5018A-FTN4 which has the Intel Atom C2758 SoC 8 core CPU
I’ve run your commands and I’m achieving similar/same speeds as my Ubiquiti EdgeRouter 4, whereas before I was getting ~880 megabit/s on the Supermicro, now ~940 megabit/s which is more or less line speed for my gbit fibre connection.
Because I have 8 cores, what would be the appropriate commands to run to enable RPS?
Dmitry
February 4, 2020, 10:33am
16
Hi @raab , I think 940 megabit/s maximum for 1gbps link. PPPoE overhead.
Check if you NICs have more than 4 queues, and bind each for own CPU.
sudo ls /sys/class/net/eth0/queues/
raab
February 4, 2020, 10:46am
17
Agreed re maximum
vyos@vyos:~$ sudo ls /sys/class/net/eth0/queues/
rx-0 rx-1 rx-2 rx-3 rx-4 rx-5 rx-6 rx-7 tx-0 tx-1 tx-2 tx-3 tx-4 tx-5 tx-6 tx-7
I’m not sure if I’m reading it right, but I’m guessing it has 8 queues?
I wasn’t sure what to echo into /sys/class/net/eth0/queues/rx-[4-7]/rps_cpus etc
Dmitry
February 4, 2020, 11:11am
18
Do next
sudo su -l
echo "f" > /sys/class/net/eth0/queues/rx-0/rps_cpus
echo "f" > /sys/class/net/eth0/queues/rx-1/rps_cpus
echo "f" > /sys/class/net/eth0/queues/rx-2/rps_cpus
echo "f" > /sys/class/net/eth0/queues/rx-3/rps_cpus
echo "f" > /sys/class/net/eth0/queues/rx-4/rps_cpus
echo "f" > /sys/class/net/eth0/queues/rx-5/rps_cpus
echo "f" > /sys/class/net/eth0/queues/rx-6/rps_cpus
echo "f" > /sys/class/net/eth0/queues/rx-7/rps_cpus
echo "2048" > /sys/class/net/eth0/queues/rx-4/rps_flow_cnt
echo "2048" > /sys/class/net/eth0/queues/rx-5/rps_flow_cnt
echo "2048" > /sys/class/net/eth0/queues/rx-6/rps_flow_cnt
echo "2048" > /sys/class/net/eth0/queues/rx-7/rps_flow_cnt
exit
raab
February 5, 2020, 12:02am
19
Perfect, thank you for that
