TRO offloading kills throughput
Hello All
New here. I’m looking for a virtualized firewall solution (XCP/XEN on HP edge line servers) so I have been looking into Vyos with some success so far. I’m on the latest build and I need some recommendations for interfaces settings on a virtualized setup. I noticed TSO offloading was on by default killing my throughput (3-7Mbps) so I disabled TSO and and SG offloading. I’m now getting 200-250Mbps in a 1gig/30 internet connection. Is there anything I can do to improve this? I’m getting full bandwidth on the outside interface?
Here is my current config:
address 10.254.250.1/24
description INSIDE
offload {
gro
gso
address dhcp
description OUTSIDE
offload {
gro
gso
Speed test on device:
Idle Latency: 24.77 ms (jitter: 18.59ms, low: 16.17ms, high: 53.99ms)
Download: 938.59 Mbps (data used: 1.0 GB)
23.48 ms (jitter: 6.41ms, low: 13.33ms, high: 263.13ms)
Upload: 54.92 Mbps (data used: 93.7 MB)
14.40 ms (jitter: 3.01ms, low: 6.31ms, high: 111.99ms)
Packet Loss: 0.0%
Yes, depending on the vNIC you choose, you can check the ring-buffer:
set interfaces ethernet ethX ring-buffer
Possible completions:
   rx                   RX ring buffer
   tx                   TX ring buffer
check the multi-quee on vNIC
sudo ethtool -l ethX
and flowtables in your configuration , it should help to increase your performance :
https://docs.vyos.io/en/latest/configuration/firewall/flowtables.html#overview
Here you got some:
Thank you. I’m figuring out that much of the interface offloading must be handled on the Dom0 level. For reasons that are well beyond my understanding this is the best I can come up with so far.
Xen Dom0 Level settings ($uuid is the physical interface uuid):
xe pif-param-set uuid=$uuid other-config:ethtool-gso=“on”
xe pif-param-set uuid=$uuid other-config:ethtool-ufo=“off”
xe pif-param-set uuid=$uuid other-config:ethtool-tso=“off”
xe pif-param-set uuid=$uuid other-config:ethtool-sg=“off”
xe pif-param-set uuid=$uuid other-config:ethtool-tx=“off”
xe pif-param-set uuid=$uuid other-config:ethtool-rx=“off”
Vyos interface settings:
ethernet ethx {
address dhcp
description OUTSIDE
offload {
gro
gso
