As the title says, it appears something about the surricata build changed, causing the current build process fail due to missing dependencies. I’ve already created a bug report, just wanted to raise the issue here as well (and crosslink the report and the forum entry).
Best regards
I can confirm that:
Some packages could not be installed. This may mean that you have
suricata : Depends: libhtp2 (>= 1:0.5.50-1~bpo12+1~) but it is not going to be installed
and this is because of
Del libhtp2 1:0.5.50-1~bpo12+1 [72.6 kB]
The missing dependency was fixed, awesome!
However, I still fail to build correctly, now I encounter this issue, seemingly around the end of the build process:
The following packages will be REMOVED:
zsync*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 228 kB disk space will be freed.
(Reading database ... 27901 files and directories currently installed.)
Removing zsync (0.6.2-5) ...
[2026-06-08 20:26:01] lb chroot_prep remove dpkg tmpfs sysv-rc hosts resolv hostname apt
[2026-06-08 20:26:01] lb chroot_apt remove
P: Deconfiguring file /etc/apt/apt.conf
[2026-06-08 20:26:01] lb chroot_hostname remove
P: Deconfiguring file /etc/hostname
P: Deconfiguring file /bin/hostname
[2026-06-08 20:26:02] lb chroot_resolv remove
P: Deconfiguring file /etc/resolv.conf
[2026-06-08 20:26:02] lb chroot_hosts remove
P: Deconfiguring file /etc/hosts
[2026-06-08 20:26:02] lb chroot_sysv-rc remove
P: Deconfiguring file /usr/sbin/policy-rc.d
[2026-06-08 20:26:02] lb chroot_tmpfs remove
[2026-06-08 20:26:02] lb chroot_dpkg remove
P: Deconfiguring file /sbin/start-stop-daemon
[2026-06-08 20:26:02] lb chroot_prep remove devpts proc selinuxfs sysfs
[2026-06-08 20:26:02] lb chroot_sysfs remove
P: Begin unmounting /sys...
[2026-06-08 20:26:02] lb chroot_selinuxfs remove
[2026-06-08 20:26:02] lb chroot_proc remove
P: Begin unmounting /proc...
[2026-06-08 20:26:02] lb chroot_devpts remove
P: Begin unmounting /dev/pts...
P: Binary stage completed
P: Saving caches...
Reading package lists... Done
[2026-06-08 20:26:02] lb source
P: Source stage disabled, skipping
P: Build completed successfully
File "/vyos/./build-vyos-image", line 810, in <module>
build()
File "/vyos/./build-vyos-image", line 743, in build
with subprocess.Popen(c, stdout=subprocess.PIPE, stderr=subprocess.STDOUT,
File "/usr/lib/python3.11/subprocess.py", line 1024, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/usr/lib/python3.11/subprocess.py", line 1901, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'syft'
Error occurred during build, not running tests!
This could definitely be a purely local issue on my setup, it’s not that clear to me yet. I’d appreciate any help.
EDIT: It indeed was an oversight on my end, I was still using the outdated docker tag ‘current’ instead of ‘rolling’. The build is working again! Marking as solved
